Signals and Systems - Example of use of SMath for signals and systems analysis - Messaggi
However I've edited the link, now it downloads the file, whatever is your favorite browser.
Thanks Davide!!
The post shows a trasfer function solved for the poles and zeros... It looks like you have to know how many poles and zeros to solve for before getting going. That would require putting the transfer function in standard form I'm somewhat sure.
https://electronics.stackexchange.com/questions/243435/bode-plot-of-transfer-function?rq=1
WroteI'm still trying to get the hand of this software. I'm an e.e. undergraduate and would like to be able to perform the something like the mathcad at the end of this post. I did try to input a similar syntax but I'm too much of a noob to work it. Can anyone shed some light on this for me?
All documents attached are in Smath 6179, should work same imore recent version(s).
The Smath/Maple companions of this year [2018] work a bit different than Mathcad 11 [2003].
At the end, all attached documents work for me Smath 6179 same as my former Mathcad 11.
Inst_PID [ODE].sm (24,75 KiB) scaricato 1104 volta(e).
Inst_PID Discrete State Systems.sm (25,51 KiB) scaricato 1338 volta(e).
Inst_PID DynSys.sm (14,9 KiB) scaricato 1253 volta(e).
Inst_PID [PI, PID].sm (71,51 KiB) scaricato 1119 volta(e).
Inst_PID [P, PD].sm (106,94 KiB) scaricato 1049 volta(e).
Inst_PID Feedback Attenuator.sm (43,76 KiB) scaricato 1280 volta(e).
Inst_PID [MCD Model].sm (177,96 KiB) scaricato 1116 volta(e).
Inst_TurboGen Smath.sm (106,19 KiB) scaricato 1305 volta(e).
ODE_Laplace Read First.sm (27,41 KiB) scaricato 1312 volta(e).
Inst_TurboGen Signum.sm (91,08 KiB) scaricato 1349 volta(e).
Inst_PID Discrete Schema.sm (166,36 KiB) scaricato 1342 volta(e).
ODE_Laplace 1rst [Type 1].sm (24,7 KiB) scaricato 1117 volta(e).
Inst_XFR 2nd [XFR nth].sm (34,08 KiB) scaricato 1120 volta(e).
ODE_Laplace 1rst [Type 2].sm (22,5 KiB) scaricato 1191 volta(e).
Inst_PID DynSys_v01 (1).sm (235,59 KiB) scaricato 1303 volta(e).
ODE_Laplace 2nd [Type 3].sm (33,42 KiB) scaricato 1129 volta(e).
ODE Laplace Kinetic Reaction.sm (93,13 KiB) scaricato 1303 volta(e).
Here's an example of how one might attack it.
Page1.sm (44,98 KiB) scaricato 1527 volta(e).
Bravo! Alyles, simple and beautiful!!
What why the invlaplace I get a dot?
Inverse Laplace-1.sm (4,08 KiB) scaricato 1350 volta(e).
Basile
WroteJean,
Basile, mon ami, you need a new pair of glasses !
Just code as the snippet, it will gladly work for Basile.
Until I get my new pair, I see that a dot appears after the F(s) when I type a comma.
Any diagnosis?
Inverse Laplace-2.sm (4,25 KiB) scaricato 1275 volta(e).
Basile
WroteJean,
Any diagnosis?
Check from "Options" if you can fix .
Can you be more specific?
Basile
WroteJean,
Basile
From the menu tool bar up top work sheet:
Tools => Options => Interface => Arguments separator [period, coma, semicolon]
Thank you,
Basile
People have done some amazing things with it that I can't even begin to follow but I haven't been as successful. Perhaps as I become more competent I might be more successful but for now I think I will unfortunately have to hang up my hat gentlemen... I bid you a respectful adieu for the time being kind Sirs...
magnetism.zip (5,26 MiB) scaricato 496 volta(e).
WrotePerhaps as I become more competent I might be more successfu
I have doctored few things in these two documents.
hw 2.6.sm (133,49 KiB) scaricato 1277 volta(e).
open loop gain from closed loop gain 2.sm (48,32 KiB) scaricato 1269 volta(e).
WroteHi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expresed in F(s) form.
enjoy
Oscar Campo
Hi. Enjoyed & Improved. Six years later.
InvLaplace2.sm (93,88 KiB) scaricato 1308 volta(e).
WroteEnjoyed
Thanks Alvaro for your dedication,
Does syntax error 6179, but does not to where it complains.
Don't worry, OK like this.
The 2nd example is lot more involved, correct [sanity MCD].
InvLaplace2 Otherwise.sm (27,68 KiB) scaricato 1334 volta(e).
