1 pagine (7 elementi)
pde in SMath - Can we solve it in SMath - Messaggi
We heated the rod in the flame of a burner.
How will it cool down?
Non-stationary mode!
One stationary mode here https://en.smath.com/forum/yaf_postst23506_Cannot-plot-T-x--y.aspx
dhoskins 05/07/2023 15:08:00
For your data set D ... 3 options:
1. Smath ainterp, cinterp ...integrate/solve(4)/zap derivative.
2. Mathcad l_p_c implemented Smath [1rst derivative, integration]
3. Thiele Smath ... symbolic derivative, integration.
If you have interest in methods [2,3] I will attach.
Since nearly ~ two weeks, Smath Studio can't be downloaded.
Replaced by Smath Solver ... a damned crippled version.
WroteFor your data set D ... 3 options:
Thanks!
I would like as here
WroteThanks!
Thiele_0 Model QUICK.sm (24,5 KiB) scaricato 1423 volta(e).
Maths EDU [l_p_c_splines TOOLBOX] Copy.sm (584,29 KiB) scaricato 1288 volta(e).
These two documents are SS 6179.
Please, confirm you can open.
Wrote... And what about the ICs?
We must use one numeric not symbolic method!
Using maple, you can try to use a maple "component" or a maple plot, which gives more flexible access to maple structured functions.
Also, there are some numerical procedures for pde's in Maxima.
Notice that in Mathcad the border conditions for δT(x,t)/δx are not considered for obtain the solution.
With SMath, you can try to adjust the curve choosing good guess values in the yellow vector.
pdesol_num.sm (14,78 KiB) scaricato 1391 volta(e).
