[XlsxImportExport] import after upgrading to 6884
[XlsxImportExport] import after upgrading to 6884 - Messaggi
#1 Pubblicato: 13/11/2018 01:47:21
dio pants
dio pants
16 apprezzamenti in 180 post.
Hi all-
The latest build and upgraded the plugins that failed the check.
I am seeing some odd behavior in my Excel imports and in the results of CurrentDirectory variable.
Here is the worksheet before the upgrade-
Here it is after the upgrade to build 6884.
Here is a CamStudio capture trying to navigate the file. I was a full screen capture, so it might be a little small unless you expand it.
https://drive.google.com/file/d/1OP_hoYvbrngJv5TjfKUlCnby8LjFY2fH/view?usp=sharing
There is no audio, but I you can see after I open it, it re-calcs and the CurrentDirectory changes and the Excel import errs out. I tried to step through things to check them- the Excel sheet, the paths, the file location, etc... makes not sense to me.
After uninstalling and rolling back to 6839, all is fine withing the same worksheet.
Anyone have any ideas?
Dennis
#2 Pubblicato: 13/11/2018 06:36:29
Gruppo: Moderator
It is related to a plugin code cleaning made recently, I've made a patch to make it working again (plugin updated).
Will try to find something more consistant later.
dio pants 13/11/2018 16:50:00
#3 Pubblicato: 13/11/2018 16:53:06
dio pants
dio pants
Davide-
Thanks for the quick reply.
On one hand, I fear that I only seem to complain and find problems. On the other hand, I am glad to contribute by helping fix things.
Know that I am grateful every time I start the program and get successful computations.
Dennis
#4 Pubblicato: 14/11/2018 10:55:39
Igor Skarine
Igor Skarine
14 apprezzamenti in 97 post.
xslx plugin fails during installation on portable Smath.
The same issue occurred on two different computers Win10 and Win7.
I have reported same bug a short while ago, it's back again.
#5 Pubblicato: 14/11/2018 11:59:38
Gruppo: Moderator
I see... will fix it in the next plugin release.
#6 Pubblicato: 15/11/2018 10:07:17
Gowand Gravi
Gowand Gravi
0 apprezzamenti in 22 post.
Same here with Windows Version. SMath shuts down while updating.
#7 Pubblicato: 15/11/2018 10:46:16
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
Yes, I too experience this problem of shut down after updating.
#8 Pubblicato: 15/11/2018 10:48:25
Gruppo: Moderator
I've removed the latest update, sorry for the issues.
I know where it was the problem, I'll be back soon with another update.
#9 Pubblicato: 15/11/2018 12:07:18
Gruppo: Moderator
Updated
NDTM Amarasekera 15/11/2018 13:01:00
#10 Pubblicato: 15/11/2018 12:50:29
Gowand Gravi
Gowand Gravi
Thank you.
#11 Pubblicato: 15/11/2018 13:02:08
NDTM Amarasekera
NDTM Amarasekera
Thank you Davide.
