Array position - another approach
Array position - another approach - Messaggi
#1 Pubblicato: 07/09/2023 12:34:24
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
I remember there were some useful posts to find the positions in an array
satisfying defined conditions.
Another approach is attached.
Array_Pos2.sm (15,2 KiB) scaricato 1771 volta(e).
5 utenti hanno apprezzato questo post
Oscar Campo 07/09/2023 16:57:00, oscar mauricio 07/04/2024 10:46:00, francesco rapuano 08/01/2025 23:06:00, sergio 07/09/2023 12:38:00, Alvaro 08/09/2023 15:06:00
#2 Pubblicato: 08/09/2023 14:59:13
Arie
Arie
94 apprezzamenti in 285 post.
To expand on this concept further, I generally avoid using augment/stack functions with vectors of indeterminate size. The reason being that there is generally quite a bit of overhead in using those functions when it comes to execution time. I propose an alternative method shown here. Firstly we perform the test on the input matrix to determine the size of the result vector and location of results in input matrix. Then we instantiate the result vector and fill it in. To demonstrate the difference in execution I've also created a 100x100 input vector and timed the execution of both algorithms. The execution time difference becomes more apparent the larger the input matrix becomes.
Mostra spoiler
Array_Pos2.pdf (137,54 KiB) scaricato 983 volta(e).
Array_Pos2.sm (44,07 KiB) scaricato 1694 volta(e).
4 utenti hanno apprezzato questo post
francesco rapuano 08/01/2025 23:08:00, Alvaro 08/09/2023 15:07:00, NDTM Amarasekera 08/09/2023 16:37:00, sergio 09/09/2023 05:57:00
