1 pagine (1 elementi)
Stable: SMath Studio 0.92 (25 February 2012) - Messaggi
New SMath Studio 0.92 Stable available
Absolutely free mathematical program with "paper"-like interface and numerous computing features (now with integrated mathematical reference book).
SMath Studio Desktop on the Desktop (Windows)
SMath Studio Desktop on the Desktop (Linux)
Last changes
- Printing bounds displaying implemented directly on the worksheet;
- Printing improved: added ability to specify pages to print, print current page only (the page where cursor is located) or to print a selection;
- Context Menu items now also added to Edit button of the Main Menu;
- Graph animations performance improved up to 20%;
- Calculations performance improved;
- Program will now cancel any try to copy selected regions to the same location as initial using Ctrl key;
- Current Region (Region with cursor inside) is now always shown on top (z-index) of others;
- Hiding of the error when removing a region fixed;
- Improved showing of the current error status of the Region;
- Print preview dialog improved;
- Plot Region error handling improved;
- Added internal support for color and alignment of the Header and Footer text on print out;
- Fixed critical error appeared when pressing on the Graph related buttons from Plot Math Panel if no Plot Region focused;
- Fixed math panels issues appeared when screen DPI not equal to 96;
- Fixed infinite loop issue appears for complex functions when math error occurs inside;
- Fixed blinking of the Separator Region on worksheet horizontal scroll;
- Several issues fixed appeared when non-standard Worksheet's scaling used;
- Fixed drawing issue appeared on Grid displaying property changed when two or more Worksheets are shown side by side within one instance of the program;
- Fixed error of the Symbolic Library appears when working with Units for expressions with numeric optimization;
- Changing of the latin symbol to greek one or vice versa using Ctrl+G repaired for Text Region;
- Fixed error appears on printing of the large Regions;
- Fixed critical error on program startup when any of snippets has no Title set by File > Properties;
- Couple of issues fixed regarding copying of content close to the collapsed Area Region;
- Fixed error popup animation issue (animated twice);
- Fixed issue appeared some times on pasting content from clipboard: region was not visible till any other user's action;
- Language files updated;
- Refactoring.
System requirements
- Desktop (Windows):
Framework: .NET Framework 2.0 - Desktop (Linux):
Interface languages
Desktop и Handheld (34 languages):
Free Download
SMathStudioDesktop.0_92.Setup.msi (Date: 25.02.2012. File size: 1.63MB)
SMathStudioDesktop.0_92.Portable.exe (Date: 25.02.2012. File size: 17.48MB) - .Net Framework 2.0 doesn't required - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_92.Mono.tar.gz (Date: 25.02.2012. File size: 809.15KB) - last version of Mono distributive required!
Note: No SMath Studio Handheld 0.92 release will be introduced. Please use the latest stable handheld version (0.90).
Tutorial
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
Other files
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
