Forum SMath SMath Studio Questions How to apply initial conditions in second-order differential equations 1 pagine (3 elementi) How to apply initial conditions in second-order differential equations - How to apply initial conditions in second-order differential equations - Messaggi Vai all'ultimo post #1 Pubblicato: 07/12/2025 03:59:55 kimkim 0 apprezzamenti in 9 post. Gruppo: User How to apply initial conditions in second-order differential equationsThe solution to the second-order differential equation has been obtained as follows.If we want to find the solution by applying the initial conditions y(t)=0, y'(t)=0,what should I do in the following steps?thank you for your help. Modificato 07/12/2025 06:53:24 #2 Pubblicato: 07/12/2025 09:07:00 StvMath 44 apprezzamenti e 1 disapprezzamenti in 76 post. Gruppo: User Once you've got y(t) you could simply do the following: 1 utenti hanno apprezzato questo postkimkim 07/12/2025 21:41:13 #3 Pubblicato: 07/12/2025 12:54:45 Martin Kraska 1.361 apprezzamenti in 2.275 post. Gruppo: Moderator If you don't need the function v(t), you can specify the initial conditions directly: (example 10.2 in https://github.com/sn-code-inside/Technische-Mechanik-mit-SMath) Technische Mechanik mit SMath Studio: https://link.springer.com/book/10.1007/978-3-658-50592-9 3 utenti hanno apprezzato questo postsergio 07/12/2025 17:07:45, kimkim 07/12/2025 21:41:18, ioan92 09/12/2025 10:52:27 1 pagine (3 elementi) Nuovi post Nessun nuovo post
