CoolProp Wrapper
CoolProp Wrapper - Pure and pseudo-pure fluid equations of state and transport properties for 122 components - Messaggi
#21 Pubblicato: 26/10/2016 05:07:40
Gruppo: Moderator
Also, no dynamic assistance is available. Though disabling the plugin doesn't help.
Dynamic assistance is enabled in the program's options?
Mike Kaganski 26/10/2016 17:00:00
#22 Pubblicato: 26/10/2016 05:39:09
Mike Kaganski
Mike Kaganski
184 apprezzamenti in 434 post.
С уважением, Михаил Каганский
Davide Carpi 26/10/2016 06:50:00
#23 Pubblicato: 26/10/2016 08:14:41
Hello Jean, according with CoolProp documentation "Q" stands for "Mass vapor quality", thus 1 is 1 mol/mol
Thanks Davide for "unitless Q" and the link to CoolProp Wrapper
Davide Carpi 26/10/2016 12:50:00
#24 Pubblicato: 26/10/2016 12:49:17
Gruppo: Moderator
Here's what I see:
Try now
Mike Kaganski 26/10/2016 17:00:00, Radovan Omorjan 26/10/2016 18:18:00
#25 Pubblicato: 26/10/2016 17:02:49
Mike Kaganski
Mike Kaganski
Thanks, Davide!
It's fixed indeed.
#26 Pubblicato: 06/01/2017 21:24:08
Gruppo: Moderator
A german smath user contacted me and asked me to include the steamtable dll for EFI in the portable distribution. They weren't included in the recent update because this involves some additional config work and I assumed that the coolprop wrapper might be a replacement.
According to the mentioned user, the steamtables are of better accuracy than the coolprop functions. Thus I now updated the portable distribution.
The user also asked for speed of sound and isentropic exponent functions. Is there a way to help him?
#27 Pubblicato: 08/01/2017 12:41:22
"WASP" is freeware for 10 minutes use, unlimited sessions.
"WASP" from "Katmar". all properties are tabulated per T(°C) or P(abs).
#28 Pubblicato: 08/01/2017 15:58:05
Gruppo: Moderator
As for the speed of sound can be accessed using "A" or "speed_of_sound"
For the isentropic functions I googled "isentropic coolprop" and there is something but it is not my field, maybe Mike can give some hints.
#29 Pubblicato: 16/05/2017 18:31:50
timgow
timgow
0 apprezzamenti in 27 post.
Hello
On entering >>CoolProp_Props("D","T",298.15*K,"P",10*bar,"CO2")=<< I receive a message "K not defined;
Are the double quotes correct?
Tim
#30 Pubblicato: 16/05/2017 19:35:12
Gruppo: Moderator
Hello Tim,
You missed the units character (apostrophe) before K and bar -> 'K, 'bar
CoolProp_Props("D","T",298.15*'K,"P",10*'bar,"CO2")
#31 Pubblicato: 17/05/2017 05:10:17
timgow
timgow
Hello Davide,
Thank you for looking into my issue.
I had indeed overlooked the apostrophe, thank you.
I copy and pasted your coolprops statement into SMath but I don't get an answer, instead a red border around the statement.
I also typed the statement in from fresh and I get the same.
Is the ordinary >> = << used on a coolprops statement? Will the answer appear before units are applied to the result?
What is the most simple test to see coolprops working?
Tim
#32 Pubblicato: 17/05/2017 05:21:36
timgow
timgow
This a screenshot of my coolprops entry, attached.Screenshot from 2017-05-17 09-14-49.png
Tim
p.s. I don't see how to paste the image; the Insert Image command asks for a URL.
#33 Pubblicato: 17/05/2017 06:51:58
Gruppo: Moderator
What's the error message now?
Simplest way to check if it might works should be:
CoolProp_get_global_param_string("version"
Also, here there are 3 worksheets to run as test
#34 Pubblicato: 22/12/2017 21:39:02
Aleksey
Aleksey
1 apprezzamenti in 2 post.
lastError="Error message couldn't be retrieved from CoolProp library (buffer size issue?); the second try returned: "
what's the problem?
#35 Pubblicato: 23/12/2017 05:47:39
Gruppo: Moderator
which versions of SMath and CoolProp plugin are you using?
#36 Pubblicato: 25/12/2017 02:27:58
what's the problem?
There may be two issues:
1. WASP is awfully involved in Basic construction. I coded it in Mathcad 11
Get the Katmar WASP [very complete] free for 2 min session, unlimited sessions.
2. The published Basic is unitless, the CoolProp is unit based,
that is enough to freaked the codes. The Mathcad version from Valery was OK.
Sorry, can't help more.
#37 Pubblicato: 25/12/2017 23:59:35
Aleksey
Aleksey
Error:
version SMath - 0.98(build 6484)
version CoolProp -
I'm try on the various Windows platforms (32/64):
good result on
Win10x64Pro, Win7x64Ultim
don't working on
Win10x86Pro, Win10x86Educ, Win7x86Pro
Best regards,
Aleksey
Davide Carpi 27/12/2017 12:43:00
#38 Pubblicato: 27/12/2017 03:43:32
This is just a comment.
Assume my firm knows nothing about Smath and you are doing a project for us
and the project requires be tracable and you would use CoolProp-Wrapper.
If you can't prove it is certified, it won't pass QA.
CoolProp-Wrapper would be rejected [as simple as that].
IMHO, from this thread, CoolProp must be doctored regardless of the
Win version and/or Smath version.
#39 Pubblicato: 27/12/2017 12:47:24
Gruppo: Moderator
don't working on
Thank you, reproduced. Something goes wrong with the wrapped 32 bit library (the coolprop dll returns both the correct result as well as an error code, hence the errors shown).
#40 Pubblicato: 16/01/2018 21:28:09
David Avila Cortes
David Avila Cortes
is it possible to run it on ubuntu 17.10 using mono?, I can't get it to work, when I try to evaluate "CoolProp_get_global_param_string("version")" I just get a little yellow message under the command that reads "CoolProp_x64", or do I need to compile the coolprop binaries ins some specific folder or is it a standalone plugin-extension?
