1 pagine (4 elementi)
Corrupted File - SMath Crash after Opening - SMath Crashes Upon Opening File - Messaggi
Are you able to open the attached file? SMath seems to crash when I open the file.
Thanks!
East Balcony Design.sm (170,94 KiB) scaricato 1294 volta(e).
Thanks!
The last region makes SMath crash regardless of the auto-calculate state.
Remove it and the file can be read.
East%20Balcony%20Design-1-95.sm (170,61 KiB) scaricato 1339 volta(e).
<region id="96" left="18" top="3051" width="77" height="32" color="#000000" bgColor="#ffffff" fontSize="8">
<math>
<input>
<e type="operand">V.u_flr</e>
<e type="operand">a</e>
<e type="function" args="3">at</e>
<e type="operator" args="2">:</e>
</input>
</math>
</region>
Davide Carpi 17/04/2018 02:53:00
How do I open the SMath file as you show? Do I simply open it in a text editor?
Thanks!
Thanks!
Seems there was an issue in math serialization, at lesat 2 arguments missing
Do you remember if the file ended in this way or there were more things?
Yes
WroteHow do I open the SMath file as you show? Do I simply open it in a text editor?
Thanks!
Yes
