Do I have to use Insert > Function in order to use solve
Do I have to use Insert > Function in order to use solve - Messaggi
#1 Pubblicato: 23/09/2022 07:54:39
mateo
mateo
0 apprezzamenti in 2 post.
I can use Solve using the command Insert > Function. But if I write the same directly without the Menu, it won't work. What could be the reason?
#2 Pubblicato: 23/09/2022 08:20:34
127 apprezzamenti in 342 post.
You should check the use of capital or tiny "s". Also only if you have installed the "Maxima" plugin you have both "solve" and "Solve" that have a different solutor and also a different form
#3 Pubblicato: 23/09/2022 09:28:54
mateo
mateo
Thank you. I wrote solve indeed with tiny s and I don't have the Maxima plugin. However, I tried it once again today and it worked.
#4 Pubblicato: 23/09/2022 13:38:41
