Variable assignment bug?
Variable assignment bug? - Messaggi
#1 Pubblicato: 01/03/2010 10:01:23
andrei
andrei
0 apprezzamenti in 3 post.
first of all - great job on this very useful and important program! I've been trying it out recently and am very impressed by the progress you're making. Keep up the good work!
I have a question about an interesting issue happening after an assignment to a variable. As you can see in the screen shot below, I've assigned the variable CGE and value, and was surprised to see it get a completely different value after this:
I'm using the latest version 0.87 on win xp pro sp3.
I've tried moving the assignment around, or changing the numbers, but the problem is still there. Assigning something in between to the same variable overrides this and set a correct value:
Could it be that the particular assignment used is somehow corrupted?
andrei
#2 Pubblicato: 01/03/2010 10:13:10
Gruppo: Moderator
Hello Andrei,
Can not reproduce this. Could you please upload the particular file as well, or try to delete CGI variable and repeat the assignment of it.
EDIT: I'v made it once, but do not know how yet. The same result like yours. It was something with 5.*10^-7. But can not get it again ????
I've found it:
First input this (use decimal point-here is comma as decimal separator)
[MATH]CGE←5,10^{-7}[/MATH]
[MATH]CGE=1,1143*10^{-5}[/MATH]
Then insert multiplication (*) between . and 10
[MATH]CGE←5,*10^{-7}[/MATH]
[MATH]CGE=1,28*10^{-12}[/MATH]
Then delete decimal point
[MATH]CGE←5*10^{-7}[/MATH]
#3 Pubblicato: 01/03/2010 10:35:25
andrei
andrei
Hello Radovan,
Thank you for the quick reply.
Deleting the original assignment and making a new one solves the problem.
Here's the file on SpeedShare:
http://www.speedshare.org/download.php?id=5B2FD90811
andrei
#4 Pubblicato: 01/03/2010 10:40:40
Gruppo: Moderator
You are welcome Andrei,
I think something was happening here (a bug maybe). Anyway, the quick remedy in these cases is to delete the expression and try it again.
#5 Pubblicato: 01/03/2010 11:53:54
Gruppo: Super Administrator
Hello, Andrei.
Radovan is right, it is because of invisible brackets appeared in the expression after some steps you've performed with it.
I have couple of reports like this, so I'll fix this soon. Thanks.
Regards.
#6 Pubblicato: 01/03/2010 12:20:36
andrei
andrei
OK. Thanks a lot for the quick reply!
andrei
