Solve Block (given ... find)
Solve Block (given ... find) - Messaggi
#1 Pubblicato: 02/05/2014 12:38:01
phillip.toone
phillip.toone
1 apprezzamenti in 6 post.
I am interested to know what it would take to implement solve block functionality into SMath. This is the one feature I feel sets MatchCad apart from SMath. Are others wanting this feature? Would it help if we were all to pony up and donate to the cause? Could we make this into a Kickstarter project? Let me know your thoughts on this. Thanks.
#2 Pubblicato: 02/05/2014 14:14:30
Gruppo: Moderator
Regarding your comment, I remembered some of my first post on this Forum - it was long time ago. Read it please and have some fun. I was a bit younger and Andrey had much more time at that time
Matcad <-> SMath ...
#3 Pubblicato: 02/05/2014 15:04:39
Gruppo: Moderator
You may give the Maxima plugin a try. It has as symbolic solve function - Solve(). For numeric problems, the function FindRoot() from the plugin NonlinearSolvers is very useful.
findroot.sm (22,78 KiB) scaricato 1815 volta(e).
Radovan Omorjan 03/05/2014 07:46:00
#4 Pubblicato: 03/05/2014 07:45:18
Gruppo: Moderator
By the way Martin,
I might missed it, but I think there is still no answer about the differences between the official (wrong) and unofficial-portable (correct) and FindRoot() example
#5 Pubblicato: 03/05/2014 07:56:06
Gruppo: Moderator
Can't reproduce this. Based on 0.97.5189 there is no difference between portable and non-portable version.
#6 Pubblicato: 03/05/2014 09:31:29
Gruppo: Moderator
This is quite strange . Could someone else else try to reproduce this please.
This is only happening to me with the official (regular) install
#7 Pubblicato: 03/05/2014 10:18:48
Gruppo: Moderator
NS version is 1.0.9999.5 for both of you (Martin and Radovan)?
#8 Pubblicato: 03/05/2014 10:24:19
Gruppo: Moderator
I confirm version 1.0.9999.5 according to plugin dir name. I also tried to change arg/dec sep settings to komma/period and get the same (correct) result.
Davide Carpi 03/05/2014 10:25:00
#9 Pubblicato: 03/05/2014 11:13:12
Gruppo: Moderator
Hello Davide,
I also confirm the plugin version - see the picture please.
BTW, this is the same on my both computers home-Win7 32bit, office-Win7 64bit
Davide Carpi 03/05/2014 11:14:00
#10 Pubblicato: 03/05/2014 11:18:37
Gruppo: Moderator
Thanks... I'll check it ASAP, just want to share the latest couple of controls and then I'll go back on this plugin
Added in BTS: SS-139
Radovan Omorjan 03/05/2014 11:21:00
#11 Pubblicato: 05/05/2014 17:58:09
phillip.toone
phillip.toone
I hate to be such a newbie and ask stupid questions but how do I go about installing the "Nonlinear Solvers" plugin? I tried this and got a request for a password. That seemed very strange to me. I am using build 4909 on Linux.
Also, I discovered that I can solve this system of equations using the "roots" function but I had to do it without units. Is this a reason to use the FindRoots method or am I just using the roots method wrong? BTW, I stumbled across the other real solution of d=2.292 and h=0.242.
I am SO much more proficient with MathCad (version 6.0+) and this frustrates me right now. I hope to be comfortable with SMath soon but it will take a bit. Once I am I plan to teach a class at my work on how to solve problems using SMath. Thanks for your help.
#12 Pubblicato: 05/05/2014 18:16:18
Gruppo: Moderator
There are no stupid questions... In the Extensions Manager (EM) some plugins are protected by passwords because are new (potentially unstable) or under development. You may find the most of them in the Extensions section of the forum. About Nonlinear Solvers here there is the official thread (and the first post contains the password).
roots/solve are really powerful but units are not supported; this is just one of the things behind the development of the plugin (BTW more or less all the algorithms of this plugin are available also as worksheets).
