Table Region Problem
Table Region Problem - Wrong display of a matrix - Messaggi
#1 Pubblicato: 27/08/2023 05:58:19
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
Hello !
I have this display problem when trying to pass
a matrix to a Table.
Table_Region_Problem.sm (11,47 KiB) scaricato 1579 volta(e).
#2 Pubblicato: 27/08/2023 09:11:12
Gruppo: Moderator
Unit summary doesn't work as it should either.
Maybe these are bugs. Regards
NDTM Amarasekera 27/08/2023 10:09:00
#3 Pubblicato: 27/08/2023 15:07:33
NDTM Amarasekera
NDTM Amarasekera
Hello !
My post #1 is a simple example to show the Table Region problem.
The actual problem is related to a Slope Stability Analysis example,
where the result consist of the following.
1. Strip width
2. Relevant Min Factor of Safety (Min_FS)
3. Center cordinates (x,y) of slip circle relevant to Min_FS
4. Corresponding Radius of slip circle.
#4 Pubblicato: 28/08/2023 04:31:21
Gruppo: Moderator
In the attached sheet I tried to automatically compile a results summary. Note that there is a single entry point for unit specification in the algorithm (no chance for mismatch between displayed unit and unit used to calculate the numerical values.
1-3.sm (137,75 KiB) scaricato 1566 volta(e).
#5 Pubblicato: 28/08/2023 07:53:00
At post #3 construct the matrix as independent cols, thus compatible Table.
Next, nest the two pertinent cols to explicit your Engineering c/w header.
#6 Pubblicato: 04/01/2024 21:52:24
Leonardo Cocco
Leonardo Cocco
0 apprezzamenti in 2 post.
When I downloaded the latest version of Smath Studio, the Table region Plugin does not updated correctly. As a consequence the files containing tables developed with the plugin do not open correctly. Is there any solution in the future for this issue?. Best regards,
Leonardo.
#7 Pubblicato: 04/01/2024 22:04:34
Leonardo.
Smath Solver 30405 is OK for my Tables.
#8 Pubblicato: 05/01/2024 01:10:03
Gruppo: Moderator
Leonardo.
New program versions might require to update code of some plugins. The release time it depends on how many plugins are affected and how many changes are required (also the Release Manager seems still not completely restored).
#9 Pubblicato: 05/01/2024 18:10:22
Gruppo: Moderator
Plugin released, thanks to Andrey for updating the code.
#10 Pubblicato: 08/01/2024 19:32:17
Leonardo Cocco
Leonardo Cocco
Thanks for your replies, they were of help.
