Allow to select result together with units when using customized units
Allow to select result together with units when using customized units - Messaggi
#1 Pubblicato: 19/05/2016 07:56:15
Mike Kaganski
Mike Kaganski
184 apprezzamenti in 434 post.
Currently, the custom units of result placeholder has scope of whole expression. So, e.g. trying to select result (15°C) in following line:
288.15*'K=15@'°C
results in whole expression being selected, not only part after "=".
If possible, please enable that selection, to make it easy to copy only result.
С уважением, Михаил Каганский
#2 Pubblicato: 19/05/2016 09:24:02
copy only result.
Maybe like this Mike.
#3 Pubblicato: 19/05/2016 12:50:48
Gruppo: Super Administrator
Jean, I think Mike requests something like this:
Will check if it is possible to implement
Mike Kaganski 19/05/2016 19:26:00
#4 Pubblicato: 19/05/2016 13:31:19
CBG
CBG
78 apprezzamenti in 312 post.
Or something like this..
Carlos
#5 Pubblicato: 19/05/2016 19:02:30
Implemented. Can be tested here: http://en.smath.info/forum/yaf_postst7566_SMath-Studio-0-98-5983--19-May-2016.aspx
Mike Kaganski 19/05/2016 19:26:00, Davide Carpi 19/05/2016 19:51:00
#6 Pubblicato: 21/05/2016 08:32:41
Mike Kaganski
Mike Kaganski
Great!
In the same time, it made it more convenient to remove result with custom units, if I decided that I don't want to see the result at all with the expression.
Before, I needed to remove custom unit explicitly, now I just put cursor to the result and hit Backspace several times.
Thanks again!
