Beta: SMath Studio 0.99.6965 (26 January 2019)
Beta: SMath Studio 0.99.6965 (26 January 2019) - Messaggi
#1 Pubblicato: 25/01/2019 19:08:58
Gruppo: Super Administrator
Offre numerose funzionalità di calcolo e un'interfaccia utente ricca, tradotta in circa 40 lingue diverse. L'applicazione include inoltre un prontuario matematico integrato.
L'applicazione può essere facilmente estesa in base alle proprie esigenze. Lo strumento integrato "Gestione estensioni" consente di accedere a centinaia di risorse, sia ufficiali che di terze parti, tra cui: esempi d'uso, plug-in, applicazioni basate su SMath Viewer, frammenti di codice, traduzioni dell'interfaccia, libri interattivi, manuali e tutorial.
Download
SMathStudioDesktop.0_99_6965.Mono.tar.gz (1,35 MiB) scaricato 2523 volta(e).
SMathStudioDesktop.0_99_6965.Setup.msi (2,23 MiB) scaricato 5051 volta(e).
Please note:
  1. There are some known bugs with Worksheet scrolling - will be addressed soon;
  2. There are some UI issues on environment with high DPI (some Custom plug-ins may not be scaled correctly).
    Please use the following to disable high dpi support if required:
To all developers:
As you may notice starting from build 0.99.6955 SMath Studio supports high DPI and in order to scale Regions correctly we have to introduce new requirement:
- Plug-in must use SMath.Drawing.Graphics instead of System.Drawing.Graphics everywhere.
or
- All Fonts created by the plug-in must have GraphicsUnit.Pixel specified as a unit and size must be multiplied by 96f / 72f in order to convert Points to Pixels.
All existing plug-ins should be updated according to this requirement as everything looks ok while system is configured to have use 96 DPI, but in all other cases scaling of Fonts in plug-ins is incorrect.
All modern platforms like iOS, Android, UWP have Pixel specified as a unit by default, so this issue appears on Windows machines only (we have it on Linux as well because of Mono).
Please let me know in case of any related questions. If you are not able to perform changes by yourself - just let me know and I will update plug-ins by myself.
Best regards, Andrey Ivashov.
7 utenti hanno apprezzato questo post
frapuano 25/01/2019 19:46:00, NDTM Amarasekera 26/01/2019 01:54:00, Radovan Omorjan 26/01/2019 03:19:00, sergio 26/01/2019 06:13:00, Вячеслав Мезенцев 26/01/2019 07:14:00, Davide Carpi 26/01/2019 07:38:00, Serg 28/01/2019 06:07:00
#2 Pubblicato: 28/01/2019 06:11:54
genf
genf
6 apprezzamenti in 72 post.
Добрый день.
В версии SMathStudio 0.99.6954 съезжают размеры вставленных картинок.
Т.е. они были вставлены и уменьшены до нужного размера, файл был сохранен.
Но при открытии они снова становятся большими, т.е. программа не запоминает манипуляции с их уменьшениями.
На старых версиях такого не было.
В версии SMathStudio 0.99.6965 можете открыть прикрепленный файл ... как там будет? Будет ли съезжать после редактирования и сохранения?
Спасибо!
Raschet glukhikh naruzhnykh nenesushchikh sten.sm (652,07 KiB) scaricato 1775 volta(e).
#3 Pubblicato: 28/01/2019 07:12:08
Gruppo: Moderator
This was a bug introduced in SS 0.99.6954, fixed in the immediately following version (0.99.6955). The choosen size was still saved but that version wasn't able to restore it properly. Your file in current version looks like in the attached picture, that I believe should be correct.
Mostra spoiler
Serg 28/01/2019 07:17:00
#4 Pubblicato: 28/01/2019 07:17:38
genf
genf
Спасибо!
Тогда обновлюсь
#5 Pubblicato: 29/01/2019 05:51:25
Oleksander.Shevchenko
0 apprezzamenti in 1 post.
Great job!
Have you planned to update the cloud version to this new one?
I find out it very convenient.
Time of desktop apps is passing by.
Good luck in your job.
#6 Pubblicato: 29/01/2019 18:43:49
Great job!
Yes, usually I'm updating Cloud version with stable versions only (with some exceptions).
