SMath Studio 0.99.6638 (05 March 2018) - Messaggi
Offre numerose funzionalità di calcolo e un'interfaccia utente ricca, tradotta in circa 40 lingue diverse. L'applicazione include inoltre un prontuario matematico integrato.
L'applicazione può essere facilmente estesa in base alle proprie esigenze. Lo strumento integrato "Gestione estensioni" consente di accedere a centinaia di risorse, sia ufficiali che di terze parti, tra cui: esempi d'uso, plug-in, applicazioni basate su SMath Viewer, frammenti di codice, traduzioni dell'interfaccia, libri interattivi, manuali e tutorial.
Download
SMathStudioDesktop.0_99_6638.Mono.tar.gz (1,28 MiB) scaricato 2650 volta(e).
SMathStudioDesktop.0_99_6638.Setup.msi (2,15 MiB) scaricato 5156 volta(e).
Utilities Matrix_Vector [MCD 4 styles].sm (34,65 KiB) scaricato 1504 volta(e).
WroteEvery time Smath Studio is updated, something goes wrong.
Yeah, its a life...
Fixed (please update a plug-in). Thank you!
Thank you very much.
Carlos
That's why I'm 6179 for productive projects.
WroteWroteEvery time Smath Studio is updated, something goes wrong.
In this case you have to live with slow performance, tens of critical known (and already fixed) bugs. You can't use new features and make your future switch to newer version harder. There is no even any guarantee that your worksheets can be supported by latest SMath Studio versions (yeah, in SMath history we had couple of such situations when a part of calculation can not be handled anymore, unfortunately).
So, I can't say that it is good approach.
WroteA bug in functionality of vectorize() was introduced between 0.99.6617 and 0.99.6638
That it was introduced between 6617 & 6638, that is surprising ?
Even if it did work, to me, it is not correct because it will cause
something wrong sooner or later, because to reflexive in the
calculation kernel ... Murphy's law. I have experimented disastrous
situations [crash ... push the button to stop].
Occasionally, to isolate, you have to spool to file.
Cheers Alex ... Jean
WroteA bug in functionality of vectorize() was introduced between 0.99.6617 and 0.99.6638. Will this be addressed?
Jean are right, this didn't work initially, but started working at some point because of another bug
I've investigated this example and was able to make it work together with all other examples I have about vectorize(..) function. All tests executed OK.
So, I decided to include this improvement into new release: https://en.smath.info/forum/yaf_postst12594_RC-0-99-6648--15-March-2018.aspx
Please test examples you have with vectorize(..) function.
