Graphs Scaling
Graphs Scaling - Messaggi
#1 Pubblicato: 10/03/2015 09:45:37
sperez
sperez
0 apprezzamenti in 1 post.
Is it possible to control the scale of the graph axes, using code within the document or an option somewhere.
I'm trying to make the scale conform to a specified domain and range so the graph generated by my functions doesn't have to be manually adjusted every time a variable is changed.
Best Regards,
Santiago
#2 Pubblicato: 13/03/2015 15:34:48
Gruppo: Moderator
Hello Santiago,
For precise scaling/limits you have to use a plugin, such as Maxima plugin (examples) or X-Y Plot Region
A further help is inside the extension mangager (Tools > Plugins...) > Interactive handbooks; here there is the SMath Studio Handbook, that contains a Graphics section. (You have to download it, set it to use as default, then will be available from the Help > Reference book... menu)
