Integration problem with user defined function with units in Latest SS 0.99.6877
Integration problem with user defined function with units in Latest SS 0.99.6877 - Messaggi
#1 Pubblicato: 30/10/2018 23:16:55
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
Thank you Andrey for the latest SS 0.99.6877.
However, I observe a problem in integrating a user defined function with units.
The attached SS document (and all similar docs) worked fine in all previous SS versions without any issue.
Malwala Reservoir Flood Capacity Estimation-Simple.sm (249,34 KiB) scaricato 1379 volta(e).
sergio 31/10/2018 05:16:00
#2 Pubblicato: 31/10/2018 03:23:38
Gruppo: Super Administrator
Thank you!
For some reason I had no automated test with such example (integral with units) and that is why I didn't catch this error before the latest beta release.
Will add example to tests and make a fix asap.
Thanks for the report!
Arie 31/10/2018 10:30:00, NDTM Amarasekera 05/11/2018 12:56:00
#3 Pubblicato: 06/11/2018 22:45:46
NDTM Amarasekera
NDTM Amarasekera
Thank you Andrey for the fix.
Andrey Ivashov 07/11/2018 02:31:00
