1 pagine (5 elementi)
How to calculate the effective value of segmented voltage waveform - There is the voltage waveform but segmented, tried to calculate the effective value but failed. - Messaggi
Dear Friends,
I tried to calculate the effective value of segmented voltage waveform, but failed, could you help me to fixed it? Thank you very mucn! RMS calc.sm (10,21 KiB) scaricato 973 volta(e).
Hi. This is a way. You can see also the file RMS in this post.
Also:
RMS-example.sm (17,81 KiB) scaricato 898 volta(e).
Also:
Modificato 09/12/2025 18:46:12
Version without killing the units:
RMS-example.sm (8,29 KiB) scaricato 906 volta(e).
In the original version, just making the periodicity function unit-proof, is sufficient:
OH! I see! Thank you Alvaro!
Wen.
Wen.
WroteHi. This is a way. You can see also the file RMS in this post.
Also:
It helps a lot, thank you very much!
wen.
wen.
WroteVersion without killing the units:
