Bypassing Default Values of Constants
Bypassing Default Values of Constants - Messaggi
#1 Pubblicato: 10/03/2023 12:14:44
ceakins
ceakins
0 apprezzamenti in 2 post.
Hi all!
I'm sure this is a really simple thing, but I seem to not be searching the right question in my forum searches... I work in the Electrical Engineering field, and as many are aware, we use i to represent current, and j to represent the imaginary unit. I've been trying to figure out how to use i as a variable in smath, but it appears everything I've tried results in i being the imaginary unit rather than used as a variable.
How do you bypass the "constant" functionality built into i in the program and use it as a variable? Also, is there a way to permanently re-assign j to be the imaginary unit within the program?
Thanks in advance!
#2 Pubblicato: 10/03/2023 14:15:17
How do you bypass the "constant" functionality built into i in the program and use it as a variable ? Also, is there a way to permanently re-assign j to be the imaginary unit within the program ?
Collapse or front end 'j' at the top of the document.
Use 'j' instead of built-in 'i'
#3 Pubblicato: 10/03/2023 15:33:00
Gruppo: Moderator
You can't totally remove i assign.
Or swap i with j via editing Constants.xml.
It is hard-embedded to smath code.
Clear(i) gives 1, which falsely results as it worked.
But it won't actually be removed by Clear().
However, you can assign sqrt(-1) or i to j.
Results placeholder can be edited with j.
And you can reassign you i result to j.
#4 Pubblicato: 10/03/2023 17:31:59
ceakins
ceakins
Thanks for the assistance! Am I understanding correctly then that there isn't a real way to assign lower case i as a normal variable and use it for a real number then? Just double checking.
I've attached a screenshot to this post of an example calculation, I don't think it will be a huge deal to substitute capital I for i in most formulas, I just need to be aware of the limitation as I and i have different connotations in my work at times. Haven't dove into the units too much with smath yet, but I have had a hard time with similar programs in the past with similar formulas as it's hard to get it to mix SI & imperial units to a desired result (i.e., inputs in amps, feet, lbs, etc to result in a lb/ft or similar)
#5 Pubblicato: 10/03/2023 19:34:36
Am I understanding correctly then that there isn't a real way to assign lower case i as a normal variable and use it for a real number then ?
Here, 'i' is scalar wild real.
#6 Pubblicato: 10/03/2023 19:39:56
Gruppo: Moderator
Actually you can, but j won't constantly swap with i.
Every worksheet should have j:sqrt(-1) at top.
i will have what you assigned. variable, real, etc.
But when you calculate something which results as sqrt(-1),
it will considered as i again.
While i still has another value,
calculation still gives it as sqrt(-1).
But when you directly call i,
it will have what you assigned.
#7 Pubblicato: 12/03/2023 13:00:06
Imaginary 'i' is pretty universal.
Very many Smath advanced functions are coded on that basis.
They will certainly not recognize 'j' ... hits the wall.
#8 Pubblicato: 12/03/2023 19:33:26
As well, 'i,j' are largely used by Smath original Designers
and the Smath Community as rows/cols indices.
#9 Pubblicato: 12/03/2023 20:02:26
Gruppo: Moderator
I wouldn't trust a man who once claimed √-1 doesn't mean anything mathematically.
And when proven wrong (as usual) he deleted his post without an excuse.
Mathematical Methods in the Physical Sciences
Boas, Mary L. (Second Edition Page 46)
#10 Pubblicato: 13/03/2023 10:28:26
Manage wisely, ignoring Bible.
Pattern Complex.sm (31,81 KiB) scaricato 1358 volta(e).
#11 Pubblicato: 13/03/2023 13:13:15
⚜ Kenny Lemens, P.E. ᵂᴵ
85 apprezzamenti in 181 post.
Greetings,
For the first part:
...we use i to represent current...Thanks in advance!
To get 'I' to be your default unit for Amp, just modify the 「C:\Program Files (x86)\SMath Studio\entries\Units.xml」 as shown below:
NOTE: if you accidently corrupt this file (i.e., SMath will not even load), you can just re-install SMath as every new install will rewrite/replace the Units.xml file.SMath_DefaultUnitsOfAmp.jpg
Mostra spoiler
As for the second part:
... j to represent the imaginary unit...
As stated, you cannot replace 'i' as the Special Variable. However, there are some trick you can use (depending on your purposes):
First: define 'j as the imaginary unit; copy and paste the following:
Citazione
'j:sqrt(-1)
Next: define a function, similiar to this:
Cn(_num):line(concat(var2str(Re(_num)),"\002B\",var2str(Im(_num)),"\002A\\0027\j",1,1)
With this defined at the top of your sheet, you can display your number (as a string) in the syntax you desire. To use it as a mathematical expression, just use the str2num() function to convert it into math. NOTE: for this to 'work,' you need to have the 'Custom Functions' plugin installed:
May this be of Good Help!
- Kenny Lemens, P.E. ᵂᴵ
