See the result on the place where the variable is defined
See the result on the place where the variable is defined - Messaggi
#1 Pubblicato: 05/11/2013 05:19:01
ISO
ISO
0 apprezzamenti in 2 post.
I have two little questions.
First if I defined a=5 and b=10, and then if I write c=a+b, is it a problem to see the result in this way c=a+b=5+10=15.
Or the same question but c=a+b=15.
It is a visual problem, but would be helpful
Thanks in advance.
Greetings
#2 Pubblicato: 05/11/2013 07:46:26
Gruppo: Moderator
#3 Pubblicato: 05/11/2013 09:28:45
ISO
ISO
Sorry, that I did not check the older topics, but at least that means that this is a wanted feature.
#4 Pubblicato: 05/11/2013 11:34:23
Gruppo: Moderator
Absolutely yes... I think that The only definition + result, without numerical expansion, would be a fantastic improvement....
#5 Pubblicato: 05/11/2013 15:16:00
Basile
Basile
8 apprezzamenti in 172 post.
Can, then, we have a second option to horizontal alignment, a vertical one?
F = m*a = 10 kg * 2 m/s^2 = 20 N
F = m*a
= 10 kg * 2 m/s^2
= 20 N
Thank you,
Basile
#6 Pubblicato: 05/11/2013 15:25:17
Gruppo: Moderator
The function Assign() from the Maxima plugin converts a boolean equation into an assignment and displays the result. This is normally used for postprocessing of Solve() and ODE.2() results.
#7 Pubblicato: 07/11/2013 08:40:10
marcofk
marcofk
8 apprezzamenti in 19 post.
Does the Maxima plugin work with a portable installation of Maxima? (I have wxMaxima from WinPenPack) Or else, Can you manually set the path to find Maxima?
#8 Pubblicato: 07/11/2013 09:57:28
Gruppo: Moderator
Yes is possible, look the image attached in the first post of the Maxima Plugin thread
#9 Pubblicato: 11/11/2013 07:24:03
marcofk
marcofk
Thanks very much.
Marco
