How to calculate the max and Min Values For 24.4±0.015?
How to calculate the max and Min Values For 24.4±0.015? - Messaggi
#1 Pubblicato: 29/07/2012 02:15:22
Mohan
Mohan
0 apprezzamenti in 5 post.
I have a data : 24.4±0.015
I want to find out the maximum without having to write a code.
How is it possible?
#2 Pubblicato: 29/07/2012 04:09:08
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
For example, the so-
http://smath.info/live/?file=3857
#3 Pubblicato: 29/07/2012 08:14:23
jabadu
jabadu
1 apprezzamenti in 37 post.
Hey, this would be a very elegant way for the analysis of tolerance chains.
But there would be a Problem:
How can you enter a value of e.g. 25 +0,1/-0,2 or 25 +0/-0,2 ??
Any ideas?
#4 Pubblicato: 29/07/2012 11:16:07
Gruppo: Moderator
It's not difficult, just use the multiple values item (type "sys(" or click on the curly bracket in the "functions" right panel)
[LIVE width=259 height=195]http://smath.info/live/?file=3861[/LIVE]
regards,
w3b5urf3r
matteob8 30/07/2012 02:19:00
#5 Pubblicato: 30/07/2012 08:01:43
jabadu
jabadu
Thanks w3b5urf3r,
but then I have the same question as in the beginning of this thread: how do I get the min / max-value of this result?
example
(btw how did you enter the preview of the live file in your post?)
#6 Pubblicato: 30/07/2012 08:34:43
Gruppo: Moderator
HI
Thanks w3b5urf3r,
example
For the max() and min() values use the snippet sys2mat() in the attachment
To show the preview click on "Get link..." in the bottom-right corner of Live SMath and copy&paste in your post the 2nd link
best regards,
w3b5urf3r
sys2mat_example.sm (11,4 KiB) scaricato 1540 volta(e).
Fridel Selitsky 17/09/2012 03:32:00
#7 Pubblicato: 30/07/2012 10:02:06
jabadu
jabadu
Great - but one problem:
I get an error message "mat()-function is not defined" on every term below the line tc:= sys2mat(tc)
I use Smath 0.95 build 4594 on linux (same also on version 0.94 on linux).
#8 Pubblicato: 30/07/2012 11:37:16
Gruppo: Moderator
Here is a screenshot from Ubuntu 12.04
No errors reported.
#9 Pubblicato: 31/07/2012 06:04:37
jabadu
jabadu
Hmmm - this looks like it's my computer (running on the older ubuntu 8.04 (server version)) that have this problem. Update is scheduled, let's see how it changes.
Another question: Does SMath have something like a median-Funktion (= find the value between two given numbers)? Because the usual production process tries to work in the middle of the tolerance field this value could also be interesting to know in a tolerance chain.
Btw, why isn't it possible to transcode a system into a matrix with a build-in function? Or enhance the min/max/lenght/... function to work also with a system and not only with a matrix/vector? Is this not a common problem?
#10 Pubblicato: 31/07/2012 07:44:39
Gruppo: Moderator
Try this SMath DEB packages. During the installation, missing dependencies will be reported, if any.
#11 Pubblicato: 31/07/2012 08:02:45
Gruppo: Moderator
Hi
You can try with linterp() or building a function like [MATH]med(A;A+/2[/MATH]
I don't know, it's not yet implemented but SMath is in continuous development and something can escape... I'm sure that in a future version there will be some improvements, specially if you report your Feature Requests... f.e. an improvement of max() and min() is requested from several users (max and min), and the support of systems is something that should be included but it's not reported
regards,
w3b5urf3r
#12 Pubblicato: 31/07/2012 09:17:08
Basile
Basile
8 apprezzamenti in 172 post.
Why I am getting different answers?
(http://www.yourfilelink.com/get.php?fid=816752&dv=1)
Tolerance
Thanks,
Basile
#13 Pubblicato: 31/07/2012 09:44:27
Gruppo: Moderator
Tolerance
Thanks,
Basile
yourfilelink.com report: "Incorrect linking code. Please try again."
can't you attach the file on your post?
w3b5urf3r
#14 Pubblicato: 31/07/2012 10:50:24
Basile
Basile
Here should be...
#15 Pubblicato: 31/07/2012 12:14:00
Gruppo: Moderator
Here should be...
it's the optimization in the definition of [MATH]R[/MATH], [MATH]R,eq[/MATH] and [MATH]R,e[/MATH] (see optimization of coloured equations in the attachment)
regards,
w3b5urf3r
sys.sm (13,59 KiB) scaricato 1466 volta(e).
#16 Pubblicato: 31/07/2012 12:19:38
Gruppo: Moderator
Pay attention how sys() is working. In this simple example, every element from both sys() are combined with each other:
[MATH=eng]sys(1,20,2,1)+sys(50,300,2,1)=sys(51,70,301,320,4,1)[/MATH]
Sometimes it behaves differently, it depends on optimization applied.
Optimization numeric:
[MATH=eng]sys(1,20,2,1)+sys(1,20,2,1)=sys(2,21,21,40,4,1)[/MATH]
Optimization symbolic:
[MATH=eng]sys(1,20,2,1)+sys(1,20,2,1)=2*sys(1,20,2,1)[/MATH]
Actually: [MATH=eng]2*sys(1,20,2,1)=sys(2,40,2,1)[/MATH]
To be honest, because sys() in the calculations can sometimes be quite confusing, my advice is to avoid it in calculations. Actually, I did not figure out yet where the sys() environment is the most useful for using - excluding plots.
#17 Pubblicato: 31/07/2012 12:42:21
Basile
Basile
Thank you both for your replies.
But how somebody will know a priori to leave the default or change the optimization?
Thanks,
Basile
#18 Pubblicato: 01/08/2012 11:57:54
jabadu
jabadu
Hello w3b5urf3r,
I found the reason why your snippets don't work on my machine. Change the decimal symbol to comma and the arguments separator to semicolon and you get the same errors. With decimal symbol "period" and argument separator "comma" everything is fine.
Haven't tested if this is a bug or a feature...
Because Andrey is improving the min/max-function in near future these snippets won't be needed any more (probably/hopefully)
greetings
jabadu
#19 Pubblicato: 01/08/2012 21:26:17
Gruppo: Moderator
Hello w3b5urf3r,
greetings
jabadu
Thank you very much...
seem it's an issue (BUG?) of the built-in functions [MATH]str2num(#)[/MATH] and [MATH]num2str(#)[/MATH] that have different behavior changing interface settings (see the attachments)
(probably the wrong behavior is in [MATH]num2str(#)[/MATH] but I'm not sure)
regards,
w3b5urf3r
num2str_str2num_bug.sm (5,32 KiB) scaricato 1447 volta(e).
#20 Pubblicato: 02/08/2012 14:16:08
Gruppo: Super Administrator
Thank you! Bug of str2num function fixed.
Regards.
Davide Carpi 02/08/2012 16:23:00
