integration accuracy
integration accuracy - Wrong numerical answer for simple integration of 1/ln(x) - Messaggi
#1 Pubblicato: 22/05/2017 18:28:13
Joey Ooi
Joey Ooi
0 apprezzamenti in 4 post.
The integral of 1/(ln(x) with limits of x from 2 to 1000 does not agree with mathlab or maxima --
The numerical value of the following integration is off -- should be 176.56 and Smath gives 177.1
Any idea what could be the problem?
Thanks
Joey Ooi
#2 Pubblicato: 22/05/2017 18:50:40
Gruppo: Moderator
Hello [userlink]Joey Ooi[/userlink],
You have to set a better accuracy in the global options (tools >> options >> calculation)
#3 Pubblicato: 22/05/2017 21:32:54
Joey Ooi
Joey Ooi
Thank you for your quick and accurate response Davide.
It was very helpful indeed.
Joey
#4 Pubblicato: 23/05/2017 07:53:55
Smath Simpson iterative integrator is known to range from
exact [sometimes] to poor. Increasing accuracy is fine in
this example but will not converge in other instances like
in the Fourier Quantum double integral. You can rescue
your example using the attached Romberg.
Mathematica online integrator link added.
Integrate Mathematica.sm (9,92 KiB) scaricato 1312 volta(e).
#5 Pubblicato: 23/05/2017 08:37:48
... revisit same work sheet for the 7 decimals !
Integrate Mathematica.sm (10,19 KiB) scaricato 1291 volta(e).
#6 Pubblicato: 23/05/2017 08:53:58
... like this
#7 Pubblicato: 23/05/2017 14:32:33
How many numerical integrators have been imagined ?
1+1+1+... Even Mathcad aren't so easy to deal with.
This visit is worth the time spent.
Fourier Quantum CoC Model.sm (36,72 KiB) scaricato 1280 volta(e).
