AppImage File Crashes on Linux Mint v22
AppImage File Crashes on Linux Mint v22 - I am using Linux Mint v22 and when I attempt to run the ".AppImage" file, it crashes? - Messaggi
#1 Pubblicato: 04/12/2024 08:11:39
Keith
Keith
1 apprezzamenti in 3 post.
I am using Linux Mint v22 and when I attempt to run the ".AppImage" file, it crashes with the following errors:
Citazione
Unhandled Exception:
System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly: type: membernull)
at (wrapper managed-to-native) System.Drawing.GDIPlus.GdiplusStartup(ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus..cctor () [0x000d4] in <728fbd68fe594062895e1f819791e76a>:0
--- End of inner exception stack trace ---
at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_generic_class_init(intptr)
at System.Drawing.Graphics.FromHdcInternal (System.IntPtr hdc) [0x00000] in <728fbd68fe594062895e1f819791e76a>:0
at System.Windows.Forms.XplatUIX11.SetDisplay (System.IntPtr display_handle) [0x0007e] in :0
at System.Windows.Forms.XplatUIX11..ctor () [0x00077] in :0
at System.Windows.Forms.XplatUIX11.GetInstance () [0x0001c] in :0
at System.Windows.Forms.XplatUI..cctor () [0x000e3] in :0
at System.Windows.Forms.Application.EnableVisualStyles () [0x00006] in :0
at .. (System.String[] ) [0x0002d] in <868b174b35bf46d7860f868d305a3a08>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: The type initializer for 'System.Windows.Forms.XplatUI' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Drawing.GDIPlus' threw an exception. ---> System.DllNotFoundException: libgdiplus.so.0 assembly: type: membernull)
Restoring environment...
TopUser2000 13/12/2024 18:44:00
#2 Pubblicato: 13/12/2024 18:46:00
TopUser2000
TopUser2000
0 apprezzamenti in 28 post.
I have the same problem on LM22 and sent this report to the developer many weeks ago but I haven't got any answer
#3 Pubblicato: 14/12/2024 13:22:07
Keith
Keith
Misery loves Company...
#4 Pubblicato: 14/12/2024 19:56:54
Gruppo: Moderator
This happens because libgdiplus in appimage has missing symlinks.
I added and recompiled appimage with libgdiplus symlinks added.
Now it works. I don't know why Andrev didn't add those links, who knows?
Download appimage linked below, I have tried with linuxmint_22 live iso.
SMathStudioDesktop.1.2.9038-x86_64-linuxmint_22.glibc2.35.AppImage.tar.gz (11,66 MiB) scaricato 1200 volta(e).
TopUser2000 16/12/2024 01:54:00
#5 Pubblicato: 15/12/2024 14:15:23
Keith
Keith
That works great... Thanks a lot!
#6 Pubblicato: 16/12/2024 02:18:17
TopUser2000
TopUser2000
Thanks so much. Now it works.
Does the sMath author have any activity? No respond of email request or forum topic.
#7 Pubblicato: 21/12/2024 18:49:02
Gruppo: Super Administrator
Hello.
Please, could you provide a script to create this appimage? We can integrate it into our build process and provide Mint v22 appimage package in future.
Thanks in advanced!
Best regards, Andrey Ivashov.
#8 Pubblicato: 24/12/2024 00:36:37
Gruppo: Moderator
Hello.
Thanks in advanced!
I did extract content of original smath appimage from terminal via --appimage-extract argument.
Added libgif.so and symlinks for libgdiplus.
Mono library replacement shouldn't be necessary, only for just in case.
Andrey, you can take my appimage and extract its content.
Only smath file updates should be enough for new appimage creation.
#9 Pubblicato: 24/12/2024 00:42:14
Gruppo: Moderator
Generally libgdiplus library is strictly depended on glibc version of system.
Usually it is creating the havoc, because of it also mono libraries too.
#10 Pubblicato: 24/12/2024 04:01:30
Thank you! Checking.
#11 Pubblicato: 27/12/2024 02:33:48
TopUser2000
TopUser2000
Could you fix the latest appImage?
#12 Pubblicato: 27/12/2024 02:52:30
Gruppo: Moderator
What do you mean by fix?
The file I have uploaded should already works for linuxmint 22.
#13 Pubblicato: 27/12/2024 02:54:23
Gruppo: Moderator
There is a new 1.3.0.9126 version
#14 Pubblicato: 27/12/2024 02:57:16
Gruppo: Moderator
There is a new 1.3 version
Really? I didn't even update my SMath.
I am going to look it, post here when it is done.
Oscar Campo 27/12/2024 18:23:00
#15 Pubblicato: 27/12/2024 11:58:03
Gruppo: Moderator
I don't know if it is only on my pc but,
New version doesn't work on linux.
When any plugin is installed,
SMath crashes when reopened.
Going to inspect further...
#16 Pubblicato: 27/12/2024 22:04:51
Gruppo: Moderator
There was some missing files for /usr/lib/mono and libgdiplus.so.
This should work now, please check it and report.
SMathStudioDesktop.1_3_0_9126.Mono.x86_64.linuxmint-22.glibc2.35.AppImage.tar.gz (11,7 MiB) scaricato 958 volta(e).
SMathStudioDesktop.1_3_0_9126.Mono.x86_64.linuxmint-22.glibc2.35.AppImage.tar.gz (11,7 MiB) scaricato 1173 volta(e).
Oscar Campo 27/12/2024 22:25:00, TopUser2000 28/12/2024 01:59:00
#17 Pubblicato: 28/12/2024 01:56:55
TopUser2000
TopUser2000
it works even with XYplot plugin)
But some text can't be imaged like in the previous version
#18 Pubblicato: 28/12/2024 02:15:50
Gruppo: Moderator
This version even works with ubuntu-24.04 along linuxmint-22.
I only added export MONO_WINFORMS_XIM_STYLE=disabled before exec mono.
It prevents a stupid mono bug keeping applications crash at start.
Change is applied to smath_launcher in appimage.
For the lacking of button texts, it is probably mono error.
Possibly I can't do anything about that.
Oscar Campo 28/12/2024 04:29:00, ⚜ Kenny Lemens, P.E. ᵂᴵ 10/02/2026 15:15:43
#19 Pubblicato: 30/08/2025 17:34:13
tr
tr
0 apprezzamenti in 1 post.
Hello.
I am relatively new to Linux and want to use Smath in Ubuntu 24.04 LTS, a program I have been using on Windows for some time. As mentioned in this forum, the .AppImage execution doesn't work. I used the modified file from Overlord and ran the command export MONO_WINFORMS_XIM_STYLE=disabled beforehand. The application opens, but after a few minutes, it crashes and closes. While it's open, I can't use the numeric keypad, and the spacebar stops working at times; it also lags a lot. I would appreciate it if someone knew what steps to follow to make it work correctly. It's a tool I would like to continue using.
Thanks!
Modificato 30/08/2025 17:35:22
#20 Pubblicato: 12/03/2026 13:55:43
Aleksi
Aleksi
Noticed that undo and redo short cuts are not working correctly. Undo is bound ctrl+w and redo doesn't work. Pressing ctrl+z opens the insert unit page. Any way to fix this?
