Symbolic result for sum(#)
Symbolic result for sum(#) - Messaggi
#1 Pubblicato: 05/07/2020 19:17:35
Hi. sum have an issue for symbolics evaluations.
#2 Pubblicato: 05/07/2020 19:36:36
Just check , Alvaro.
Between yourself and me ... we are old kookoo in those games !
#3 Pubblicato: 05/07/2020 20:51:36
Gruppo: Moderator
You are correct, bug reproduced.
Definitely there are some issues.
Perhaps it is not only sum related too.
Alvaro 06/07/2020 03:46:00
#4 Pubblicato: 06/07/2020 03:45:56
Hi. Thanks Overlord. I don't see these other problem. What make troubles for me is the fact that sum don't returns the symbolic values but numerical approximations, in this case for sqrt(17). I expect to see sum(vec) = 5/sqrt(17) instead the rational showed. I introduce the "x" value just for check if sum have some eval() function somewhere. But then ... ups, another issue simplifying 1+4.
#5 Pubblicato: 06/07/2020 04:00:32
Gruppo: Moderator
sum.sm (11,67 KiB) scaricato 1523 volta(e).
Alvaro 06/07/2020 12:49:00
#6 Pubblicato: 06/07/2020 07:17:28
I see no bug ...
NOBUG.sm (30,88 KiB) scaricato 1453 volta(e).
#7 Pubblicato: 06/07/2020 12:48:31
Hi. Some notes attached.
sum.sm (20,39 KiB) scaricato 1462 volta(e).
sum.pdf (66,13 KiB) scaricato 818 volta(e).
#8 Pubblicato: 07/07/2020 07:34:39
