SHOW EQUATION, NOT RESULT
SHOW EQUATION, NOT RESULT - Messaggi
#1 Pubblicato: 22/09/2020 08:37:20
LeandroMartins
LeandroMartins
1 apprezzamenti in 9 post.
Hello everyone.
I have an If shown in the image below. I would like that in addition to the result of the equation, it would also be shown from which equation the result originated.
It is possible?
#2 Pubblicato: 22/09/2020 09:37:22
It is possible?
Maybe ... but document is missing ... Ah !
#3 Pubblicato: 22/09/2020 10:14:47
127 apprezzamenti in 342 post.
Leandro, for example like this:
Leandro.sm (7,13 KiB) scaricato 1214 volta(e).
As Jean says help us get help and always attach the smath file with the problematic example.
#4 Pubblicato: 22/09/2020 11:37:05
LeandroMartins
LeandroMartins
Thank´s so much Sergio. It´s Works very nice.
Next time I will put smath file.
Attach the math file only to check my solution. But this is in Portuguese!
Memoria de Calculo Monovia.sm (243,67 KiB) scaricato 1176 volta(e).
#5 Pubblicato: 22/09/2020 17:41:26
Hi. Those are very similar to the Sergio (Pompelmo Tell) solution:
#6 Pubblicato: 23/09/2020 09:31:24
Often, if/otherwise is more convenient in program.
In some applications, program accepts only if/else.
Generally < is incompletely determined ... ≤ is completely determined.
It may result in an error message or simply an error w/o message.
if-else ... if-otherwise.sm (21,1 KiB) scaricato 1178 volta(e).
