Positioning of expression stops recalculation
Positioning of expression stops recalculation - It appears that positioning the expression before defining variables affects output - Messaggi
#1 Pubblicato: 24/11/2020 19:49:50
Mark Berelowitz
Mark Berelowitz
0 apprezzamenti in 1 post.
File non trovato.File non trovato.File non trovato.
In the first case, the variables are defined, and then the expression, then the variables are changed, but the result doesn't update with recalculate.
In the second case, the expression is defined before the variables. When changing the variables, the result updates.
Why does this happen?
Thanks
Mark
#2 Pubblicato: 24/11/2020 20:53:03
churichuro
churichuro
29 apprezzamenti in 79 post.
in the first case you are defining the values and then an expression,
the expression is evaluated and no longer depends on the external variables ...
while in the second case you are defining a function without parameters,
so in this second case the value changes as you change the value of your variables.
#3 Pubblicato: 24/11/2020 23:08:17
Better work algo style !
