programming syntax problem
programming syntax problem - Messaggi
#1 Pubblicato: 18/03/2013 09:03:42
dan
dan
0 apprezzamenti in 4 post.
this might be a stupid question, but here it goes:
i am trying to increment a value while a given expression is false.
used to just saying something like i++ for that, but i don't know the language sMath is based on.
i am getting an error :"output value must be defined for the called procedure"
the example is attached.
ty for you're help.
#2 Pubblicato: 18/03/2013 10:37:23
kilele
kilele
134 apprezzamenti in 397 post.
Hi, this discussion about "local variables and functions" might be of help
http://en.smath.info/forum/yaf_postsm5930_Functions-behave-differently-in-0-9.aspx#post5930
Edit:
just put b.wall after the while loop
dan 22/03/2013 15:23:00
