Measurment units bug?
Measurment units bug? - Can't add degreeC to the variable - Messaggi
#21 Pubblicato: 17/09/2021 08:08:24
Porschaka
Porschaka
2 apprezzamenti in 5 post.
Hello
I think the following can be done
Carlos
I think it is the best solution for now, Thank you, Carlos!
Oscar Campo 17/09/2021 08:12:00
#22 Pubblicato: 17/09/2021 10:59:44
Quick Units converter.
#23 Pubblicato: 17/09/2021 14:41:27
Gruppo: Moderator
Jean, I have to ask you to stay on-topic.
There is clearly a bug, and since these units are non-linear you cannot bypass the issue with simple workarounds.
Using a parallel system of units might come in handy in some specific cases, but is useless if you cannot link it with other built-in units and check simensional inconsistencies.
Oscar Campo 17/09/2021 15:09:00
#24 Pubblicato: 17/09/2021 16:36:57
Arie
Arie
94 apprezzamenti in 285 post.
It may be a bug because it doesn't evaluate. But what should it evaluate to?
My argument would be 3016.65 degC!
#25 Pubblicato: 17/09/2021 17:07:41
Arie
Arie
Workaround that preserves units.
Also confirms my assertion above.
#26 Pubblicato: 19/09/2021 11:46:58
Gruppo: Moderator
Multiplying a variable by a nonlinear unit seems to make SMath forget or ignore the definition of that variable in that cell. Thats a bug for sure.
However, if you store that multiplication in another variable and then evaluate that in another cell, the original variable is again in the context and the correct result is shown. Thus, separation of definition and display via storage in a new variable is a possible solution to the original problem.
If it is just about parallel usage of dimensional and non-dimensional quantities, then just swapping definitions might also help.
This means deriving the non-dimensional quantity from the dimensional one instead of the other way around.
Worksheet2.sm (7,94 KiB) scaricato 1208 volta(e).
sergio 19/09/2021 14:18:00, NDTM Amarasekera 19/09/2021 14:29:00, Oscar Campo 19/09/2021 22:38:00
