[SS-2340] user-defined order of computation ignored
[SS-2340] user-defined order of computation ignored - matrices & vectors - Messaggi
#1 Pubblicato: 09/05/2016 10:59:24
Tirastriel
Tirastriel
0 apprezzamenti in 2 post.
Here is in attachment files illustrating wrong computation of local variable.
Using version 0.98 (build: 5935)
bug.sm (7,04 KiB) scaricato 1364 volta(e).
#2 Pubblicato: 09/05/2016 11:12:24
Mike Kaganski
Mike Kaganski
184 apprezzamenti in 434 post.
Seems that it incorrectly optimizes the order of evaluation (despite brackets explicitly set).
This looks like a bug.
Aside, please note that this may be simplified like at the top of the screenshot.
Submitted SS-2340
A workaround:
And BTW, you may rewrite your Module() like this:
because scalar multiplication of vectors is sum of products of their corresponding elements multiplied by cos of angle between them - and for identical vectors, cosine is 1.
С уважением, Михаил Каганский
Davide Carpi 09/05/2016 11:48:00
#3 Pubblicato: 09/05/2016 13:20:20
Tirastriel
Tirastriel
Thanks for quick answer with tips, I'll use it
#4 Pubblicato: 09/05/2016 22:38:11
Define as function for greater functionality/elegance.
#5 Pubblicato: 11/05/2016 00:32:06
Basile
Basile
8 apprezzamenti in 172 post.
Jean,
Are you using matrices curved lines?
I get squares.
Thanks,
Basile
#6 Pubblicato: 11/05/2016 11:54:12
Jean,
Are you using matrices curvedlines?
I get squares.
Basile,
I'm at Smath 5346. The matrix square bracket came recently
with some of the latest nightly build. Smath 5346 does not
have the matrix square bracket, which I love very much.
The 2nd level bracket in formula is still missing [I think ?].
Cheers, Jean
#7 Pubblicato: 11/05/2016 23:55:16
Basile
Basile
Jean,
Any idea why does not evaluate but gives error message?
Basile
#8 Pubblicato: 12/05/2016 00:08:22
Jean,
Basile
...as it looks there is a pair of missing brackets in eval(,)
#9 Pubblicato: 12/05/2016 04:34:02
Gruppo: Moderator
More or less is the same bug... the preprocessing now simplify the expression (affects only the last version)
0.98.5973
previous versions
