Transpose
Transpose - Glitch in transpose with Smath - Messaggi
#1 Pubblicato: 15/04/2016 15:12:43
Ruben Sidranski
Ruben Sidranski
17 apprezzamenti in 465 post.
See attached. Including file and screenshots. Looks like the second transpose of D is using the Debye moment definition! Getting rid of units, the transpose of D equals the transpose of Q
Transpose Bug.sm (7,56 KiB) scaricato 1312 volta(e).
#2 Pubblicato: 15/04/2016 18:08:06
That's what I have explained before: maths are unitless.
Units is an associated math system, each procssing.
I can see Mathcad 15 was modified [after my war against units].
#3 Pubblicato: 15/04/2016 18:12:48
Ruben Sidranski
Ruben Sidranski
Did you see my last screen shot?
#4 Pubblicato: 15/04/2016 18:19:58
CBG
CBG
78 apprezzamenti in 312 post.
For some reason , units outside the brackets of the vector, are causing the problem in the transposition of the vector
Transpose Bug_1.sm (15,11 KiB) scaricato 1314 volta(e).
Transpose Bug.sm (15,57 KiB) scaricato 1340 volta(e).
#5 Pubblicato: 15/04/2016 19:04:35
Mike Kaganski
Mike Kaganski
184 apprezzamenti in 434 post.
You keep "defining" *modified values* - like here: you try to "define" what "transposed Q" is.
This is what you actually do:
transpose(Q):mat(50,80,1,2)*'gal/'min
Don't you see what's going on? Yes, you simply override built-in transpose. Everything is correct.
С уважением, Михаил Каганский
#6 Pubblicato: 15/04/2016 21:32:36
Ruben Sidranski
Ruben Sidranski
In this case ... no, I did not notice the ":=" on the Transpose of Q (too fast for my own good!). I was having this happen on 5 other sheets ... This was a sample. I will check the other sheets to see if i did the same thing. Thanks for pointing that out
