Hard to create the expression a:=b|c
Hard to create the expression a:=b|c - BTS issue SS-55 - Messaggi
#1 Pubblicato: 12/01/2013 10:46:35
Gruppo: Moderator
when trying to generate a table of function values for boolean operators I found the input behaviour of OR, AND and XOR quite confusing.
typing a:1|0 or a:1&0 I get
[MATH]a:1|0[/MATH] and [MATH]a:1|0[/MATH]
This is not what I expected. Instead, I have to use braces to make sure the boolean operation is evaluated before the assignment operation:
[MATH]a1|0)[/MATH] and [MATH]a1|0)[/MATH] by typing a: (1|0
This implies that the assignment operator has higher priority than boolean AND, OR and XOR, which is odd. I guess that the design intent is that AND, OR and XOR take lower priority than numeric comparison operations. This facilitates writing conditionals like
[MATH]0
However, precedence over assignment is confusing. What sensible boolean result is the assignment operator supposed to provide?
Thus I propose to re-adjust the operator precedence, such that there is no need to bracket the rhs of an assignment.
Edit: Additionally, the equal and not-equal operators silently adopt the same lower precedence like the mentioned boolean operators, but do not enforce brackets around their operators. This leads to wrong results.
Davide Carpi 31/01/2013 12:51:00
#2 Pubblicato: 03/05/2013 17:56:47
Gruppo: Moderator
The issues remain open in 0.96, in particular the cited issue is dangerous.
