Natural fractions
Natural fractions - How can I enter a value to display the integer and fractional part - Messaggi
#1 Pubblicato: 21/10/2022 04:00:17
Юрий
Юрий
0 apprezzamenti in 1 post.
Natural fractions. How can I enter a value to display the integer and fractional part, like 2½. Maybe somewhere there is a full-fledged Help?
#2 Pubblicato: 21/10/2022 07:59:41
Natural fractions.
... Maybe like this
#3 Pubblicato: 21/10/2022 10:42:57
⚜ Kenny Lemens, P.E. ᵂᴵ
85 apprezzamenti in 181 post.
Greetings!
I understand your question, but such a feature isn't built into SMath. However, there are ways to mitigate this lack of support.
If you wish for special characters (e.g., 「½」) to be treated as a number, you can declare then as such:
½:0.5
      There are a few of these fraction characters you can define as a variable:
If you wish to type a fraction in as you propose (2½ ), this isn't so easy. You can use a matrix and then add the values together (i.e., Σ[2 ½]). This reads kinda like a fraction, but is needlessly bulky:
sum(mat(2,½,1,2))
If the goal is to have the result of 2.5 itself to report as 2½ instead of 5/2; there isn't much you can do. The one thing you can do is create a function that will convert your number and report that fraction as type "string"
Hope this helps!
#4 Pubblicato: 21/10/2022 11:49:46
churichuro
churichuro
29 apprezzamenti in 79 post.
easy
2+1/2
#5 Pubblicato: 21/10/2022 11:57:51
Natural fractions.
... make it algo style utility.
#6 Pubblicato: 21/10/2022 12:15:46
Oscar Campo
Oscar Campo
135 apprezzamenti in 309 post.
Gruppo: Moderator
Maybe this can help:
dec2frac.sm (6,59 KiB) scaricato 1307 volta(e).
Alvaro 24/10/2022 00:51:00
#7 Pubblicato: 22/10/2022 08:55:34
Natural fractions.
... lat brick in the wall from not acknowledged.
Stuff Forum.sm (12,14 KiB) scaricato 1362 volta(e).
#8 Pubblicato: 24/10/2022 21:55:59
Norm Schutzkus
Norm Schutzkus
9 apprezzamenti in 90 post.
"dec2frac(decimal)" Works for me! Thank you! I've been using a sheet from MathCad, which is not as clear:
Feet Inches and Fractions.sm (38,21 KiB) scaricato 1288 volta(e).
Alvaro 25/10/2022 01:12:00
#9 Pubblicato: 25/10/2022 01:17:33
Even the Oscar's solution is very elegant, this is another approach, based on the Nasch work.
Feet Inches and Fractions.sm (40,62 KiB) scaricato 1332 volta(e).
Feet Inches and Fractions.pdf (166,57 KiB) scaricato 916 volta(e).
As an application, using a vernier (the English version here, but without the students comments)
