Maple Wrapper do not start correctly in Portable Smath Studio(Last release)
Maple Wrapper do not start correctly in Portable Smath Studio(Last release) - Messaggi
#1 Pubblicato: 12/11/2018 07:43:48
frapuano
frapuano
13 apprezzamenti in 115 post.
Hi Uni
sorry for bothering but I have installed the last Smath Studio portable and I have seen that it is not already installed the Maple wrapper so I installed it using the on line gallery but as soon as I enter any maple command , for instance simply : Maple(a)-> I have the following error message:
Cmaple.exe - Application error
The application was unable to start correctly (0xc0000018).Click OK to close the application
and when I click OK on the right side of the equal sign comes up "empty"
The computer where is installed everything runs Win 10.
Herewith a System Information report:
SMath Studio: SMath Studio Desktop 0.99.6839.38235 portable, 32-bit (WoW64)
OS: Microsoft Windows NT 6.2.9200.0; Windows 10 Pro, 64-bit
Screen: 1366x768 px, 96x96 dpi, 96 GP.DPI, 1 GP.SRF
Localization: language=ENG; dec.symbol=; arg.separator=; OS dec.symbol=; OS arg.separator=; OS d.g.separator=
Framework: CLR 4.0.30319.42000
installed versions:
v2.0.50727 2.0.50727.4927 SP2
v3.0 3.0.30729.4926 SP2
v3.5 3.5.30729.4926 SP1
v4
Client 4.7.02046
Full 4.7.02046
v4.0
Client 4.0.0.0
Plugins:
- [AppDir] Area Region - 0.99.6839.38235
- [AppDir] HTMLFileType - 1.14.6839.38235
- [AppDir] ImageFileType - 1.11.6839.38235
- [AppDir] Math Region - 0.99.6839.38235
- [AppDir] PictureRegion - 1.10.6839.38235
- [AppDir] PlotRegion - 1.11.6839.38235
- [AppDir] SMath Viewer Files Plugin - 1.1.6839.38249
- [AppDir] SMathFileType - 1.11.6839.38235
- [AppDir] SpecialFunctions - 1.12.6839.38235
- [AppDir] StandardToolboxButtons - 1.1.6839.38235
- [AppDir] TextRegion - 1.11.6839.38235
- [AppDir] XMCDFileType - 1.12.6839.38235
- [UserDir] ALGLIB® - numerical analysis library - 1.0.6840.23858
- [UserDir] Checkbox Region - 1.0.6824.28978
- [UserDir] CheckBoxList Region - 1.0.6825.7135
- [UserDir] Combobox Region - 0.1.6831.35128
- [UserDir] ComboBoxList Region - 1.0.6824.37612
- [UserDir] Conditionally Formatted Label - 1.0.6824.33886
- [UserDir] CoolProp Wrapper - 6.1.6824.40902
- [UserDir] Custom Functions - 1.1.6831.35137
- [UserDir] Custom Glyphs - 1.1.6831.35146
- [UserDir] Data Exchange - 1.1.6824.33288
- [UserDir] Development Tools - 1.0.6827.19962
- [UserDir] DotNumerics - 1.1.6840.23884
- [UserDir] EFI for SMath Studio - 1.0.6840.23893
- [UserDir] Excel Files Plugin - 1.3.6824.36522
- [UserDir] FFTPACK - 1.0.6825.4311
- [UserDir] GPC Wrapper - 1.0.6824.41024
- [UserDir] Hyperlink Region - 1.0.6845.23292
- [UserDir] Image Region - 2.99.6829.23358
- [UserDir] include - 0.1.6840.23908
- [UserDir] Maple Wrapper - 1.0.6845.22105
- [UserDir] Mathcad File Access Functions - 1.0.6840.23914
- [UserDir] MaximaPlugin - 1.98.6834.42892
- [UserDir] Modeller Region - 1.0.6831.35166
- [UserDir] Nonlinear Solvers - 1.1.6824.38033
- [UserDir] Numeric Up-Down Region - 1.0.6831.35174
- [UserDir] ODE Solvers - 0.1.6840.23958
- [UserDir] PDF Files Plugin - 1.0.6824.36367
- [UserDir] Pie Chart Region - 1.0.6831.35186
- [UserDir] RadioButtonList Region - 1.0.6827.32763
- [UserDir] Slider Region - 1.0.6831.35196
- [UserDir] Snapshot Region - 1.0.6827.19688
- [UserDir] Statistical Tools - 1.0.6824.32561
- [UserDir] Structural Beam Analysis Utility Functions - 0.1.6825.6494
- [UserDir] Table Region - 0.2.6828.19951
- [UserDir] Writer Region - 0.12.6833.23058
- [UserDir] XLSX Import/Export - 1.1.6824.33002
- [UserDir] X-Y Plot Region (JXCharts) - 0.2.6850.3263
in the plugin dir -> 32dfd679-8cfd-483a-b79a-19d5ea838750, I see that there is a dir 1.0.6845.22105 and an .ini file ->config.0_99_6839_38235 that has a name that is different from the previous dir.
Attached there is the Log.txt file. log.txt (581 B) scaricato 1108 volta(e).
If I do not use the portable version and Install Smath from scratch and then the Maple wrapper everything works .
Unlukily on the non portable Smath Studio installation it doesn't work ( better to say I am not able to make it work) the Maxima Plugin so I am in a deadly embrace situation and there in no installation where they both work ( the Maple wrapper and the Maxima plugin) .
Best regards and thanks in advance for any help.
Franco
#2 Pubblicato: 13/11/2018 10:34:34
frapuano
frapuano
Uni,
Sorry for bothering again on this subject, do you have any idea if is possible to solve this issue otherwise if there is no other possibility or to solve it is necessary too much effort , I'll give up and I'll to go ahead using both the Portable Smath Studio for the Maxima usage and the last release of Smath Studio for the Maple wrapper usage .
Franco
#3 Pubblicato: 13/11/2018 14:05:37
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
I'm thinking.
#4 Pubblicato: 14/11/2018 05:37:45
Gruppo: Moderator
Have you tried to solve this problem by searching the web?
Fix : Application was unable to start correctly 0xc0000018 error in Windows
I can't reproduce your problem on my machine.
frapuano 14/11/2018 16:19:00
