Solving overdetermined systems of linear equations
Solving overdetermined systems of linear equations - Messaggi
#1 Pubblicato: 25/11/2016 16:08:21
Brian Runagle
Brian Runagle
13 apprezzamenti in 27 post.
I was reminded by the posts in, New variable programmatically; also: Solving under/over defined system of linear eqautions,
that I'd recently used an algorithm for overdetermined systems that I'd unearthed in Wikipedia:
I've documented it's use very simply so that even I'll know how to use it next time it's needed. (memory gets a lot worse with age ) Perhaps others will find it useful.
https://smath.com/wiki/GetFile.aspx?File=LinearEquationSystems.sm
Brian
frapuano 25/11/2016 16:27:00, Alexander O. Melnik 25/11/2016 18:09:00, Davide Carpi 25/11/2016 19:18:00
#2 Pubblicato: 25/11/2016 18:11:04
Alexander O. Melnik
Alexander O. Melnik
127 apprezzamenti in 498 post.
Gruppo: Moderator
Thanks alot; always good toclean up a worksheet from unnecessary plugin calls.
#3 Pubblicato: 25/11/2016 19:52:59
The β snippet represents the 'Cholesky' solver, used directly
for fitting polynomials to noisy data set. It is also the basic
solver in association with the "Conjugate Gradient".
bdrunagle 26/11/2016 04:57:00
