1 pagine (8 elementi)
ODE2 - Not a proper differential equation? - Messaggi
And there are also some approach using maxima engine/command?
WroteAnd there are also some approach using maxima engine/command?
Sure. Here is one using Maxima's desolve function and one using ODE.2 (without solving for the integration constants)
RLC.sm (23,17 KiB) scaricato 1673 volta(e).
Feder-Masse.sm (23,13 KiB) scaricato 1686 volta(e).
Martin, do you have an example for a third order differential equation on how to solve it? because ode2 is limited to second order differentia eq as far as I understood. And my previous question was on how to sollve a differential eq of order > 2 (3, 4, etc)?
Here I cirumvent the limitations of the translation using multiple intervals of integration. Example from the interactive handbook.
Worksheet36.sm (40,73 KiB) scaricato 2380 volta(e).
