1 pagine (4 elementi)
[Maxima Plugin] is a custom Maxima function call-able in SMath - Can SMath call a custom Maxima function? - Messaggi
I have defined a function in Maxima but am unable to call it in SMath... I've searched around and tried a bunch of different syntaxes buy am still new to this so if it does indeed work I couldn't get it going... Any help would be appreciated.
Attached are the Maxima .mac file and the SMath file attempting to call it.
func_gradient_divergence_curl.7z (329 B) scaricato 702 volta(e).
calling custom Maxima function.sm (4,01 KiB) scaricato 1262 volta(e).
WroteAny help would be appreciated.
Forget what does not work outside of native Smath
Maths Grad_Div_Curl.sm (12,21 KiB) scaricato 1334 volta(e).
WroteI have defined a function in Maxima but am unable to call it in SMath... I've searched around and tried a bunch of different syntaxes buy am still new to this so if it does indeed work I couldn't get it going... Any help would be appreciated.
It seems that there is a conflict with the vector package (load(vect) is executed at maxima startup in the plugin). If you remove that call, then your macro is loaded. I only tried this in wxmaxima. See Insert> Maxima> Log> wxm to see what the plugin does at startup.
![2018-05-22 18_24_27-SMath Studio - [lcm.sm_].png](/it-IT/files/Download/MLoM7B/2018-05-22-18_24_27-SMath-Studio---[lcm.sm_].png)
