How to make the comments for text or plot or pucture regions - How to make a commenst in pop-up like in the text-region - Messaggi
That is only available for text regions, which might be translated into different language.
Same feature is not available for other objects (images, graphs) which cannot be translated
WroteIf I understand correctly, you are referring to pop-up with multilanguage text.
thank you very much.
Then the question occurs by me, how can one act this 'Text Region', is this a plugin?
thanks in advance
Right-click on a text region, you will have the chance to "change language" to the text, thus writing the same sentence or word in every different language you want.
Hoovering the mouse on the sentence will then display different languages in the pop-up. You can set which language to display (when multiple are available) in your SMath settings.
WroteTo write a sentence with a space in it, or placing " before writing a word... that will turn the sentence or word into a "text" from SMath point of view (named Text Region, something that is obviously not calculated, not stored as variables, and so on..)
I understood how this works. Thanks for the help.
Best regards,
Andrey
.gif)
