Three equations and more unknown variables
Three equations and more unknown variables - Can Findroot solve three equations with more than three unknown variables? - Messaggi
#1 Pubblicato: 25/11/2023 21:33:51
Sarvesh Ambekar
Sarvesh Ambekar
0 apprezzamenti in 5 post.
Hello All,
I have four unknowns in three linear equations. In this setup, can the FindRoot function get values for these variables?
I tried the same in MathCAD and could get the solution, but it is not working in Smath.
Can someone guide me, please?
Are there other possible solving methods for handling such equations with 6 or 8 unknowns?
File non trovato.[aFile non trovato.ttach]48521[/attach]File non trovato.
Saviind
#2 Pubblicato: 25/11/2023 23:14:54
Gruppo: Moderator
Usually al_nleqsolve() is more capable at this kind of situations.
Also your functions shouldn't have boolean operations.
#3 Pubblicato: 25/11/2023 23:40:21
Gruppo: Moderator
Solve() from the Maxima plugin can handle under-determined systems of equations. In such cases, the solution contains a free variable. The name changes every time the sheet is recalculated. If you want to rely on that name, insert a MaximaControl("restart" ) command to reset the Maxima session and the counter.
Trial_Kr.sm (41,8 KiB) scaricato 1790 volta(e).
#4 Pubblicato: 30/11/2023 02:08:00
... I tried the same in MathCAD and could get the solution, but it is not working in Smath....
Hi. Can you share the Mathcad result? This page is the help for matlab techniques for handling underdetermined systems: https://www.mathworks.com/help/matlab/math/systems-of-linear-equations.html#bt7ov7u
Writing the system as a linear one, SMath have some functions for work with those systems, like this one
Trial.sm (61,84 KiB) scaricato 1681 volta(e).
#5 Pubblicato: 01/12/2023 19:40:17
For your f(x,y,z) ... I get two sets of solved [x,y,z].
Smath solves the Mathsoft example, 4 unknowns.
Smath Butller is lot more advanced/difficult.
Jean.
Solve FindRoot f(x,y,z) ITERATIVE.sm (103,87 KiB) scaricato 1834 volta(e).
