problem with "str2num"
problem with "str2num" - the function is not evaluated correctly - Messaggi
#1 Pubblicato: 17/06/2019 13:36:00
127 apprezzamenti in 342 post.
I need to evaluate a condition (Boolean) that I have to build on a case-by-case basis. In testing this situation, I experienced the incorrect behavior of the "str2num" function in the case of the "=" sign.
str2number_z.sm (4,22 KiB) scaricato 1393 volta(e).
#2 Pubblicato: 17/06/2019 20:22:08
Clearly a bug it does not recognize 'Numeric'
#3 Pubblicato: 17/06/2019 20:42:28
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Try this.
sergio 18/06/2019 06:14:00, NDTM Amarasekera 18/06/2019 06:20:00
#4 Pubblicato: 18/06/2019 05:36:23
thank you uni, it's a good buffer solution; only a minimum discomfort remains for entering the correct character.
