Description region - Formatting of description region - Messaggi
Best wishes,
Artur
Frame boundary applies the math region, NOT description.
Background description, from any of the 16 pre-set colors.
Typical ... Pink, Chartreuse, light gray ...
WroteFont color applies to the math region, NOT description.
Completely agree, hence the feature request to extent the full formatting capabilities to the description region.
1. compose the math region.
2. click on the background of your pre-set choices.
3. show description text ... background [2].
4. background math region otherwise at will.
WroteI rarely use white [254,254,254] bottom left background.
You lost me there. Are you saying it is possible to change the colour of description background (see below) from the default yellow?
WroteYou lost me there. Are you saying it is possible to change the colour of description background (see below) from the default yellow ?
That's what I have just explained [1, 2, 3]
Before [1, 2, 3] ... install your preferred background colors
WroteWroteYou lost me there. Are you saying it is possible to change the colour of description background (see below) from the default yellow ?
Before [1, 2, 3] ... install your preferred background colors![]()
Great! I do struggle to replicate your steps though. Do you have an example by any chance? Also, when you say "install your preferred background colours", what do you mean by that?
WroteGreat! I do struggle to replicate your steps though. Do you have an example by any chance? Also, when you say "install your preferred background colors", what do you mean by that ?
Visit Samples posted a minute ago.
All exemplified, mostly last page.
Jean.
WroteWroteGreat! I do struggle to replicate your steps though. Do you have an example by any chance? Also, when you say "install your preferred background colors", what do you mean by that ?
Jean.
Thanks Jean. I think we misunderstood each other. I was proposing to change the background of the description region/field, rather than the input region, as your example shows. Something like this:
WroteI was proposing to change the background of the description region/field, rather than the input region, as your example shows.
This is not possible.
In fact, I asked for this 10 years ago.
Alteration of descriptions not implemented since.
Text regions doesn't have description too.
Asked for this also, no change so far.
Long word short, don't rise your expectations.
WroteIt's not possible change the background color of description region.
This is not persistent. Possibly just a visual bug.
Background color changes to description text is not saved.
I checked with an external text editor, no data saved related to it.
They are same with yellow background and colorful highlighted.
When you save file, close it and reopen it all colors will revert.
Either to latest selected background or yellow.
But, before I posted, I did that check you mention. I saved the file, then closed SMath, reopened, and the colors remain...
WroteIt is a very strange behavior...
Close smath, reopen with a blank page, change background color to white, close file without saving.
Now reopen smath with the file you saved, background highlight should be gone.
you're right...
it's only a bug
Thanks!!
... live and image
live will be dead white because new Smath document for you.
Compose the background to get it live.
Wrote... Maths Description Background.sm (33,75 KiB) scaricato 1713 volta(e).
... live and image
Previusly reported here. No change in the background of description region, only the text is highlighted, but is not permanent, was checked as a bug here
Background it isn't a "windows tool", it is a property of an item; the description region is an item like everything else on the program canvas. As such it can be enhanched by Andrey almost in any way.
Text highlight inside description is not saved, as already discussed, there's no need to add examples bind to create more confusion to whoever will try to replicate something that doesn't works.
The feature request is clear, and it is technically feasible, since the text region already has these features. Any workaround not related to the description region itself is pointless here, since has a cost in terms of features (the description is binded to the region, is multilanguage, can be retrieved and passed as a string to the math regions, shown or hidden without loosing the data contained... ).
Wrotewas checked as a bug
Not a bug, just a fact Smath does not save this Windows facility.
Smath saves itself only, thus not Windows background.
All that said, simply a local convenience.
However, superb for publishing *.PDF document.
Maths Description Background Image.sm (53,7 KiB) scaricato 1676 volta(e).
WroteThe feature request is clear, and it is technically feasible, since the text region already has these features.
If you manually edit smath file with a text editor, font size of description can be changed.
However; font color, background color, etc couldn't be altered via this way.
FontSize persists through reopening of file too, if you don't save it again.
Unfortunately when you save it in smath, it removes fontSize attribute from description properties.
So in order to my opinion, these requests are not that hard to be implemented.
