1 pagine (3 elementi)
Unexpected behavior - Messaggi
Hi. I can not understand why the argument of the last function "disappears"
Thanks in advance
Thanks in advance
The answer is in dec2bas(x,b).
In the third row there is x
x-m)/b; arguent:something inside the function is a pass-by-reference operation from the function to the argument, hence the behavior (900 becomes 0).
If you don't want it, assign x to an internal variable and do all the definition operations on that variable (f.e. z:x -> z
z-m)/b)
sergio 23/08/2018 13:04:00
WroteThe answer is in dec2bas(x,b).
In the third row there is xx-m)/b; arguent:something inside the function is a pass-by-reference operation from the function to the argument, hence the behavior (900 becomes 0).
If you don't want it, assign x to an internal variable and do all the definition operations on that variable (f.e. z:x -> zz-m)/b)
Tante grazie Davide! I did not know where else I could look for the error, because I thought I had reviewed everything.
Davide Carpi 23/08/2018 20:52:00
