error calculating sin function
error calculating sin function - Messaggi
#1 Pubblicato: 19/03/2013 17:50:13
studoc
studoc
0 apprezzamenti in 17 post.
Looking down through a sheet I had just completed I found a curious result for a simple sin calculation, but can't fix it....
I did see someone else in here with a similar problem, another forum member suggested changing optimisation to numeric, I did this, but with no change to the result.
Can someone else check, to ensure I'm not crazy...?
If d=35, then 1-sin(d)= 0.4264, not 1.4282 as Smath reports........
cheers,
Stu.
#2 Pubblicato: 19/03/2013 18:09:49
Gruppo: Moderator
Hello Stu,
By default, it is assumed that a dimensionless variable representing angle is in radians - not degrees.
[LIVE width=235 height=204]http://smath.info/live/?file=4390[/LIVE]
