Some bugs calling composite functions with if() or cases()
Some bugs calling composite functions with if() or cases() - Messaggi
#1 Pubblicato: 18/11/2020 14:25:14
Hi. I don't know if this is a know one. I guess they are related to the fact that functions with if can neither be derived nor integrated. Notice that seems that there are a bug in cases() too.
FunctionBug.sm (13,6 KiB) scaricato 1474 volta(e).
FunctionBug.pdf (48,97 KiB) scaricato 857 volta(e).
sergio 18/11/2020 15:27:00
#2 Pubblicato: 18/11/2020 16:21:23
... and issues in composite functions with loops.
FunctionBug2.sm (17,71 KiB) scaricato 1469 volta(e).
FunctionBug2.pdf (76,58 KiB) scaricato 880 volta(e).
sergio 18/11/2020 16:45:00
#3 Pubblicato: 18/11/2020 16:47:05
Debugging with trace(), what I see is that when calling g, f takes phi=1, (this is the first phi=1 in the output window) but don't do the loop. Calling f isolated shows another phi=1 and subsequent values for phi.
With for(3) gives an error, so I can't debug that. Additionally, calling with for(4) seems to have the same behavior than while.
#4 Pubblicato: 18/11/2020 17:48:24
1. You must assign "cases" like in your last example.
2. Before Davide introduced "cases" it was a damned job integrate
unless from discrete finite differences like in the old days.
The min(x) style [undocumented] is quite smart, mostly OK Simpson.
Integrate Discontinuous [min(x)].sm (16,04 KiB) scaricato 1294 volta(e).
#5 Pubblicato: 19/11/2020 08:30:09
Gruppo: Moderator
As I've already mentioned here and there, assignments shouldn't be made inside cases() arguments, because:
Please be careful however, since a symbolic evaluation to show the function content or a failed evaluation with an error triggered on the conditions leads to the evalution of all the options.
In general currently is better to use cases to host just dead content (numbers, strings, variables).
This is a downside that currently can't be prevented. As you can see making the assignment outside cases() works as expected.
