DotNumerics
DotNumerics - Initial-value problem for nonstiff and stiff ordinary differential equations ODEs - Messaggi
#21 Pubblicato: 01/08/2018 12:54:24
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Simple test 2.
DotNumerics.ode.test2.sm (21,23 KiB) scaricato 1767 volta(e).
DotNumerics.ode.test2.pdf (79,99 KiB) scaricato 879 volta(e).
sergio 01/08/2018 18:06:00, Radovan Omorjan 02/08/2018 03:05:00
#22 Pubblicato: 01/08/2018 21:57:14
Simple test 2.
Works nice conventional/visual [6179].
That document, if it would come from other designer
would pass my QA [Quality Assurance].
DotNumerics.ode.test2.sm (24,51 KiB) scaricato 1863 volta(e).
#23 Pubblicato: 09/09/2018 14:23:36
Gruppo: Moderator
It seems that all the dotnumeric ode solver functions fail to add the last step to the solution. In the given example, the exact solution is (approximately) met if the end value of x is increased by one step (x_end/steps).
The sheet is easily extended to whatever ode solvers by adding their name to the search list. The actually available solvers depend on what plugins are installed.
Section Math ODE precision.sm (23,66 KiB) scaricato 1917 volta(e).
frapuano 09/09/2018 17:18:00, Вячеслав Мезенцев 10/09/2018 05:37:00
#24 Pubblicato: 10/09/2018 06:48:25
Gruppo: Moderator
Updated for SS 0.99.6824. Intervals issue fixed.
sergio 10/09/2018 07:02:00, frapuano 10/09/2018 09:23:00, NDTM Amarasekera 10/09/2018 09:48:00
#25 Pubblicato: 06/12/2018 14:42:53
Gruppo: Moderator
Updated.
Changes:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
#26 Pubblicato: 24/12/2018 09:13:53
Gruppo: Moderator
Updated.
2018-12-24_17-06-48.png 2018-12-25_04-33-23.png 2018-12-25_04-34-24.png dn.ode.test2.png dn.ode.test1.png 2018-12-24_17-07-41.png
dn.ode.kinetic1.sm (8,26 KiB) scaricato 2016 volta(e).
dn.ode.kinetic2.sm (12,59 KiB) scaricato 1884 volta(e).
dn.ode.kinetic3.sm (12,28 KiB) scaricato 1957 volta(e).
dn.ode.test1.sm (19,58 KiB) scaricato 1959 volta(e).
dn.ode.test2.sm (18,88 KiB) scaricato 1940 volta(e).
dn.ode.Amplitude detector.sm (20,17 KiB) scaricato 1988 volta(e).
dn.ode.kinetic1.pdf (77,42 KiB) scaricato 1110 volta(e).
dn.ode.kinetic2.pdf (93,05 KiB) scaricato 1036 volta(e).
dn.ode.kinetic3.pdf (91,31 KiB) scaricato 1029 volta(e).
dn.ode.test1.pdf (115,72 KiB) scaricato 1013 volta(e).
dn.ode.test2.pdf (120,44 KiB) scaricato 995 volta(e).
dn.ode.Amplitude detector.pdf (148,87 KiB) scaricato 1049 volta(e).
4 utenti hanno apprezzato questo post
NDTM Amarasekera 24/12/2018 09:44:00, sergio 24/12/2018 11:04:00, frapuano 24/12/2018 14:23:00, Radovan Omorjan 24/12/2018 14:52:00
#27 Pubblicato: 25/12/2018 14:49:08
Native works as well.
You can try rkfixedSteven.
#28 Pubblicato: 25/12/2018 16:25:11
frapuano 25/12/2018 19:01:00
#29 Pubblicato: 09/12/2021 09:10:25
Gruppo: Moderator
SMath Studio compatibility
Plugin updated.
Changes:
- added support the mathematical form of the problem for ODE solvers;
- refactored.
sergio 09/12/2021 11:40:00
#30 Pubblicato: 20/12/2021 16:18:13
Gruppo: Moderator
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
#31 Pubblicato: 21/08/2022 02:43:28
Hi Viacheslav. There are an issue with Implicit and dn_ExplicitRK45, just in the first element. Please see the attached.
dn_ExplicitRK45 issue.sm (8,42 KiB) scaricato 1769 volta(e).
#32 Pubblicato: 22/08/2022 03:12:45
Gruppo: Moderator
Plugin updated.
Changes:
- fixed values of initial conditions in the output array for dn_ImplicitRK5() and dn_ExplicitRK45().
sergio 22/08/2022 04:19:00, Alvaro 23/08/2022 20:15:00
