import file ?
import file ? - Messaggi
#1 Pubblicato: 17/06/2021 12:16:00
mnorena
mnorena
0 apprezzamenti in 13 post.
is it possible to import a file in txt to the smath and organize it by columns and rows???
#2 Pubblicato: 17/06/2021 13:49:55
Gruppo: Moderator
If you mean a comma separated file (csv), yes it is possible with importData().
#3 Pubblicato: 17/06/2021 15:39:09
mnorena
mnorena
I allow your instrruccions, i dont know if i am doing ok, the name of the file is "ppp" and it shows me in the smath studio thats it is not reconized.
#4 Pubblicato: 17/06/2021 15:49:26
Gruppo: Moderator
If you could provide your file, it would be easier to check and input correct delimiters.
If you don't want to, just put a couple of lines. It can help to determine the function values.
#5 Pubblicato: 17/06/2021 16:18:48
mnorena
mnorena
this it is the file, thanks for your help
ppp.txt (168,34 KiB) scaricato 1187 volta(e).
#6 Pubblicato: 17/06/2021 16:27:20
Gruppo: Moderator
You should write "ppp.txt" where you indicate your file.
You also just have to delete the first line from your data file.
It creates conflict between your function and data.
Data it provides don't match pattern of function.
So in result data can't be read.
Check below.
Mostra spoiler
PS: martin is also right about getting partial data down below.
#7 Pubblicato: 17/06/2021 17:12:18
Gruppo: Moderator
You can access differently formatted sections by reading them separately.
import.sm (4,81 KiB) scaricato 1228 volta(e).
