Function and units
Function and units - Messaggi
#1 Pubblicato: 23/05/2019 15:53:20
mgklein
mgklein
0 apprezzamenti in 10 post.
Hello.
I've been following several posts for Q&A for some days about my doubts, but one about Units is not yet solved.
I've been trying to solve a simple problem for air density to practice.
The units always stand in my way and I am interested in how you guys would solve this: ignoring units and not using the built-in constants or make everything converted before handling the problem?
My sheet and the problem I'm trying to get the same results are in the images below.
Is there a way to make the function in a programming line ? Like the other software?
Couldn't get the answers by other's questionings.
Thanks in advance.
#2 Pubblicato: 23/05/2019 16:18:03
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Try this.
Barometric formula.sm (9,31 KiB) scaricato 1250 volta(e).
#3 Pubblicato: 23/05/2019 16:23:32
mgklein
mgklein
Thanks!
I'll try it myself and see if it works.
#4 Pubblicato: 23/05/2019 16:27:09
Gruppo: Moderator
As for the odesolve block it not yet finished. You must use functions like rkfixed() to solve the ODE.
#5 Pubblicato: 23/05/2019 16:38:19
mgklein
mgklein
Good to know.
I'll try it.
Thanks
#6 Pubblicato: 23/05/2019 19:36:46
Just lost my long reply ...
The only possible programming line is the conditional .
NO software can't calculate otherwise than by segment
because Air is not an homogeneous media. So, NO single
formula, NO ODE can represent.
The attached will give you specific kg/m³ up to 85 km geopotential.
Naturally, don't put any units in there. Append unit in result.
Please don't hesitate for more Q & A
The 3 segments collected page 6/6
Inst_ISA.sm (138,45 KiB) scaricato 1205 volta(e).
#7 Pubblicato: 23/05/2019 20:43:12
Maybe there was a typo in the attached document.
Please: check, correct as needed.
#8 Pubblicato: 23/05/2019 21:36:56
mgklein
mgklein
Thanks.
I'll study the document.
#9 Pubblicato: 24/05/2019 00:22:17
The J(x) upper segment was borrowed directly from Mathcad 11.
