1 pagine (10 elementi)
Automatic numbering sections book - Messaggi
A template about how to create automatic numbering sections, figures, tables and equation labels.
Automatic numbering sections book.sm (84,05 KiB) scaricato 1682 volta(e).
Razonar,
How do you start from paragraph 1? preferably 0?
Thanks,
Basile
PS. Can this be extended to have an automatic Table of Contents, List of Figures, List of Tables, and List of Equations?
Thanks,
Basile
WroteRazonar,
Thanks,
Basile
Hi Basile. You can start from any paragraph pointing the value of the variable '§, for example from paragraph six is: '§:mat(5,1,1)
For paragraph 1 use zero as starting value.
Yes, I it's possible automate the TOC, but I don't know how to catch in the SMath document the page number, so, I can do that but manually adding it. Index at the end of the attached.
Automatic numbering sections book.sm (85,25 KiB) scaricato 1330 volta(e).
Вячеслав Мезенцев 30/09/2018 06:42:00
Very nice
I guess you can add the code in a function to reduce the code repetition and call only that function on the region placeholder
One day I'll resurrect the sections region project
WroteVery nice
I guess you can add the code in a function to reduce the code repetition and call only that function on the region placeholderOne day I'll resurrect the sections region project![]()
Yes, it's possible, let's me see if can do that.
Here, my old mcad 11 project for numbering pages.
numbers.zip (151,39 KiB) scaricato 442 volta(e).
numbers.pdf (343,84 KiB) scaricato 1125 volta(e).
I never looked outside the document...
Any table of contents, figures, tables, equations, possible?
Thank you.
Basile
Thank you.
Basile
Hi. The One-Function version, with TOC at the end.
Automatic numbering sections book v2.sm (38,76 KiB) scaricato 1421 volta(e).
Davide Carpi 01/10/2018 03:25:00
You can display the index at the begin of the document if you assign it to an absolute variable at the end (those variables starting with a tilde ~)
On german keyboards, the tilde has to be copied from a text region as it is catched as a hotkey for boolean = in math regions).
BTW, why don't you use formatted labels?
![2018-10-01 09_58_08-SMath Studio 0.99.6839 - [Automatic%20numbering%20sections%20book%20v3.sm].png](/it-IT/files/Download/S7nvyG/2018-10-01-09_58_08-SMath-Studio-0.99.6839---[Automatic%20numbering%20sections%20book%20v3.sm].png)
Automatic%20numbering%20sections%20book%20v3.sm (40,27 KiB) scaricato 1640 volta(e).
Hi Martin. Thanks for the update about global variables. I don't use formated labels because I want only to show how get automatic numbering into several SMath documents with native SMath tools. Without any doubt with formated labels it will looks great.
The formated label version.
Automatic numbering sections book - Formated label.sm (36,59 KiB) scaricato 1579 volta(e).
5 utenti hanno apprezzato questo post
Вячеслав Мезенцев 01/10/2018 21:10:00, frapuano 02/10/2018 06:05:00, sergio 21/01/2020 08:38:00, Igor K 01/10/2024 17:44:00, Thiago Pereira 10/06/2025 02:34:07
