Sys to vect and the other way around
Sys to vect and the other way around - Convert a sys to a vector and a vector to a sys - Messaggi
#1 Pubblicato: 27/04/2022 16:38:18
Mario Acevedo
Mario Acevedo
0 apprezzamenti in 11 post.
Dear friends, is there a function to convert a "sys" to a "vector" and a function to convert a "vector" to a "sys"?
#2 Pubblicato: 27/04/2022 17:12:34
Gruppo: Moderator
mat2sys(), mat2sys.1()
sys2mat(), sys2mat.1()
These are the functions you need.
You will need to install Custom Functions plugin for those.
#3 Pubblicato: 27/04/2022 18:41:32
Mario Acevedo
Mario Acevedo
Thank you very much!!
#4 Pubblicato: 27/04/2022 19:21:50
#5 Pubblicato: 27/04/2022 20:24:22
... you may not need the transition.
#6 Pubblicato: 28/04/2022 08:09:13
The Unwrap(M) algo is commonly used in projects.
#7 Pubblicato: 28/04/2022 08:10:12
Gruppo: Moderator
Unwrap() is not what owner of topic asked. Non-relevant.
João Felipe Seráfico Melo 28/04/2022 09:47:00
#8 Pubblicato: 28/04/2022 08:11:15
Gruppo: Moderator
#9 Pubblicato: 28/04/2022 11:47:25
There is a good reason to collect a project in system.
You can add/remove ... once collected or at time of collection.
... augment by clicking on the place holder of system.
... push down from top
... insert .
The attached example was collected this way by the Originator.
Simply plotting a zombie parrot from conversion.
At this point, the appropriate adjacency matrix was designed,
resulting in the desired W truss.
Collaboration appointed several visits ... done.
If you have something specific on the design board, let's go.
Page9 sys2mat.sm (24,33 KiB) scaricato 1550 volta(e).
