SMath Studio 0.98.5953 (19 April 2016)
SMath Studio 0.98.5953 (19 April 2016) - Messaggi
#1 Pubblicato: 19/04/2016 17:20:36
Gruppo: Super Administrator
SMath Studio 0.98.5953 available
Latest changes (against SMath Studio 0.98.5952)
  • Added ability to assign variables/functions put into the vector/matrix;
  • SS-129: Linear indexing for matrices is now fully supported;
  • SS-2321: Behavior of error(..) function in case when empty error is specified fixed;
  • SS-2323: Buttons on toolboxes updated and tooltips provided;
  • Several minor issues introduced by previous nightly build fixed;
  • Refactoring.
Download
4 utenti hanno apprezzato questo post
Mike Kaganski 19/04/2016 17:55:00, Davide Carpi 19/04/2016 19:19:00, Вячеслав Мезенцев 19/04/2016 23:18:00, NDTM Amarasekera 20/04/2016 08:28:00
#2 Pubblicato: 20/04/2016 10:41:21
Ruben Sidranski
Ruben Sidranski
17 apprezzamenti in 465 post.
Not sure about the different syntax for linear indexing.
Does the "[" do something different?
#3 Pubblicato: 20/04/2016 11:49:16
Hello.
Not sure I understood your question.
Linear indexing for matrix was buggy in previous versions. In latest one it is finally fixed. Please see http://smath.info/bts/Issues/IssueDetail.aspx?id=129 for details.
P.S.: Yes, I've used "[".
Davide Carpi 20/04/2016 12:54:00
#4 Pubblicato: 20/04/2016 13:29:53
Gruppo: Moderator
  • Nice feature
    if possible I suggest to improve the error message when the LHS doesn't fit the RHS (something like "wrong assignment pattern")
    Andrey Ivashov 20/04/2016 18:42:00
    #5 Pubblicato: 20/04/2016 14:13:00
    Ruben Sidranski
    Ruben Sidranski
    Andrey,
    a[1 and a[2 do not need the "j" variable. In your screen shot, a[3=a[1,2 in my file and a[4=a[2,2
    I've attached my fileIndex.sm (8,35 KiB) scaricato 1676 volta(e).
    #6 Pubblicato: 20/04/2016 14:40:37
    I understand nothing in here. You can create matrix as you wish [Smath 5346]
    #7 Pubblicato: 20/04/2016 14:58:47
    Gruppo: Moderator
    Linear indexing is a feature to identify an element of a matrix using a single number (base 1 index, starting from the top-left element, proceeding by columns and then by rows]
    [1 2 3 4]
    [5 6 7 8]
    [9 .....]
    Previously it was possible to use el(2) (one-index element) on matrices only in these cases:
    - to set elements in column vectors:
    - to get elements of column vectors;
    - to get elements of row vectors:
    - to get elements of matrices;
    Assigning elements in matrices or row vectors wasn't possible:
    In the meanwhile, a bug was introduced and it was possible to use el(2) in the LHS of assignments for any matrix, but in a wrong way.
    Now it is possible to use this feature to get and set elements of any matrix:
    Andrey Ivashov 20/04/2016 18:35:00
    #8 Pubblicato: 20/04/2016 16:25:50
    Ruben Sidranski
    Ruben Sidranski
    So its the el(2) function!
    Not sure about the different syntax for linear indexing.Does the "[" do something different?
    That is why I was asking if Andrey was using "[" to define the matrix. I may have a use for the indexing which is why I was asking.
    #9 Pubblicato: 20/04/2016 16:59:31
    Ruben Sidranski
    Ruben Sidranski
    I have had an install problem with the 0.98.xxxx series versions, installer locks up. I need to go into task manager and kill the install screen after updating or installing fresh at this window.
    If I put my mouse over this box, in Windows 7 (32 and 64), I get the mouse cursor to go to an spinning wheel. Program works fine in all installs otherwise.
    #10 Pubblicato: 20/04/2016 17:02:08
    Mike Kaganski
    Mike Kaganski
    184 apprezzamenti in 434 post.
    Hurray! I finally found something to write to this thread!
    OK, seriously, I'm really excited with this recent progress, and my constant flow of bug reports isn't meant to discourage Andrey; to the contrary, I wish this projest to prosper and flourish, and to be as problem-free as possible.
    Andrey, thank you for this new build and for all your work!
    EDIT: Oh, I feel so stupid! I wrote "Enter", while I must had written "Arguments delimiter (mine is semicolon)".
    С уважением, Михаил Каганский
    #11 Pubblicato: 20/04/2016 17:11:10
    Ruben Sidranski
    Ruben Sidranski
    I second this
    AND all of the developers for plugins, etc.
    Mike, I cannot reproduce. I just updated on of my machines to this build. I go into the resulting matrix and the red cross bar "kicks out" into white space. However, on another existing file that was working correctly, it won't open
    #12 Pubblicato: 20/04/2016 18:38:38
    That is why I was asking if Andrey was using "[" to define the matrix.I may have a use for the indexing which is why I was asking.
    el(2) and "[" is actually the same.
    Davide Carpi 20/04/2016 19:06:00
    #13 Pubblicato: 20/04/2016 18:39:43
    Hello Collabs,
    From a matrix result, you can do 3 things immediately besides
    conventional matrix algebra [rotation, transpose, rotation, inverse ...]
    1. drag/select, copy/paste element
    2. extract indexed element
    3. post process [arithmetic, function]
    Be careful on [3] versus other CAS [Matlab, Mathcad ...]
    #14 Pubblicato: 20/04/2016 18:47:14
    Bingo! I'm beginning to be afraid of you
    Just kidding! Really, thank you very much for your help! I think it is just impossible for me to catch such issues (critical issues BTW) by myself.
    Best regards!
    Davide Carpi 20/04/2016 19:06:00, Mike Kaganski 20/04/2016 19:20:00
    #15 Pubblicato: 20/04/2016 18:53:35
    You need to open Plugins tab in Extensions Manager, switch to Online Gallery and find & install all available updates there. After SMath Studio restart you will not see this error anymore.
    I'm working on the wizard which will assist users to do this semi-automatically on every SMath Studio update as it is the most common issue now.
    Davide Carpi 20/04/2016 19:06:00, Mike Kaganski 20/04/2016 20:59:00
    #16 Pubblicato: 20/04/2016 22:05:43
    Ruben Sidranski
    Ruben Sidranski
    ... switch to Online Gallery and find & install all available updates there.
    I forgot to switch to online
    #17 Pubblicato: 20/04/2016 23:45:00
    Mike Kaganski
    Mike Kaganski
    Wouldn't it be better to also check for available plugins updates and notify users of that regardless of event of main program update? To make it less intrusive, a toolbar informational icon could do the job, that, when active, on click would open relevant update window. By the way, current SMath update window is IMO too intrusive, too, and could be integrated into such informational system as well.
    #18 Pubblicato: 21/04/2016 00:25:18
    I love the bracket style and more operators.
    Thanks Andrey, Jean
    #19 Pubblicato: 28/04/2016 01:58:27
    Mike Kaganski
    Mike Kaganski
    Why is the content creation date in MSI is shown 11/12/2009?
    Actually, I needed this information when I noticed that this release was released twice: I have been notified by update manager and updated promptly, and haven't been notified again after that, but I started to see files that are "created with a newer SMath version" - 0.98.5953 (the same as mine), but last (fourth) part of version was greater.
    #20 Pubblicato: 29/04/2016 01:43:07
    Alexander O. Melnik
    Alexander O. Melnik
    127 apprezzamenti in 498 post.
    Gruppo: Moderator
    Spotted matrix definition bug if using Clear():
    Also nested definition is not supported? In a form of
    el(el(M,1,1),1,1):5
