Some Snippets Do Not Show in Extensions Manager -> Snippet Window
Some Snippets Do Not Show in Extensions Manager -> Snippet Window - Some of the snippets in the snippets folder are not accessible inside smath page - Messaggi
#1 Pubblicato: 08/01/2015 12:36:06
Ryan Freund
Ryan Freund
20 apprezzamenti in 339 post.
Why are some files saved in my snippets folder not available to select shen looking in the tools -> snippet manager ?
Attached is an example of such file.
Masonry - Pier.sm (73,58 KiB) scaricato 1360 volta(e).
#2 Pubblicato: 08/01/2015 21:02:33
Gruppo: Moderator
You must define a snippet shortcut to have a valid snippet, otherwise is just a smath worksheet in the snippet folder.
go to: File > Properties > File Atributes
#3 Pubblicato: 08/01/2015 23:04:02
Ryan Freund
Ryan Freund
Someday that thank button will work... or not.
Thank you!
#4 Pubblicato: 09/01/2015 11:39:29
Ryan Freund
Ryan Freund
Your solution works and is better than what I was doing but it is still odd that when you use tools -> Snippet Manager that some files populate while other do not.
